Question about Sport & Outdoor - Others
Adventages of an arch bridge - Sport & Outdoor - Others
How do I install arm arch linux on my hisense c11 chromebook? yes it is a ARM rock chip processor
Is your chrome book ARM Arch?
Arch Linux ARM is a distribution of Linux for ARM computers.
Jan 07, 2017 | Computers & Internet
Tip
What to do when the microwave is arching.
Hi.
If your microwave cavity is crossed by luminous discharges of current , and you see flashing arches of current from the magnetron area to other areas of the microwave oven cavity, then we commonly say that the microwave is arching.
The first thing to do in this case is disconnecting power immediately, and trying to remove the cause of arching if possible.
Arching will damage the microwave oven, if it goes on for enough time.
Any metal conductive object, such as a spoon or a fork will cause arching if left inside the oven when the microwave device (the magnetron) is operating.
Ensure that there is no metal object inside, while the appliance is operating.
Some vegetable with an high amount of metal , and some other ingredient, like bacon , are known to cause arching in sporadic cases.
In that case add a little water to the food in the oven and try again.
Sometimes recycled paper, or use of containers that are not for microwave can also cause arching. In that case use a different container, or paper.
If there is arching and bad burnt-plastic-like smell with any food being cooked, that means that there is a major problem, and that if the oven is used in this condition, you may get further damage to the appliance. In some case there may also be safety concerns.
As said, you get arching inside microwave when inside the cavity there is a strongly conductive object, such as a metal object or carbon residue.
You also get arching when the oven cavity is damaged.
In this last case the cavity may have lost insulation, and it is better having the oven repaired by a technician, that will also conduct a radiation leak test on the appliance to prove its safety.
To attempt fixing the problem by yourself , you can do the following:
Disconnect power cord.
Check inside the oven cavity, ensure that there is no foreign object inside (such as a small screw). Check also under the turntable.
Check that the light and the magnetron covers are well in place.
Clean the cavity thoroughly, clean also the lamp enclosure if this can be accessed. Carbon residue from food may be causing the arching.
If after cleaning the arching is still there, that means that the cavity is damaged. In that case better calling a technician.
A damaged microwave may loose insulation , and this may be very dangerous for health.
If you want to contact a technician, the best thing to do is ringing the phone number listed on the appliance owners manual.
Ginko.
on Feb 06, 2010 | Microwave Ovens
Why do i not have dash or tail lights on my 1990 f250
From my experience it's usually the fuses, check all of them. It's easy to tell which one it is because they often look burnt / blackened on the top. If you're not sure, shine a flashlight through it, the small metal wire inside should look like a horseshoe shaped arch. When they burn out, the arc is usually melted or broken - or there is a gap preventing the electrical connection. If a fuse is not the problem, the next thing I'd check is the switch itself. Remove the unit ( or the wires going to it ) and make sure that all the wires are connected, and that there's no corrosion on the wire clasp. If they're a little loose just crimp them with pliers. (When the wires to the switch are exposed, you can bridge them with a small piece of wire, the lights should come on when you do - that way you can tell for sure if it is the switch) The only other thing I can think of is the ground wire, without it the circuit can't bridge. So if all else fails, find the ground and make sure it's connected firmly, and that there's no dirt, oil or rust preventing the current from grounding. Hope I helped, Grim
Sep 29, 2014 | 1990 Ford F250
American camper tent 2455 setup
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Apr 09, 2013 | Sport & Outdoor - Others
Apr 09, 2013 | MSR Family Tents
DVP NS710H unlock the region code. I could not unlock it using the hacks provided on http://www.videohelp.com/dvdhacks/sony-dvp-ns710h-b/10156
muntejaya as i observed; instead of providing any solutions, you only post advertisements for all type of dvds. Lots of people click on this page for help and you just take adventage of it.
May 01, 2010 | Sony DVP-NS710H/B DVD Player
MITSIBUSHI WS65809 TV
Good Day, GLENN;
I assume that IHVT was arcing from the side, and the audio is from the TV and not stereo? Or was it the high voltage splitter? Was it plug in or soldered IN? It sounds like you may have bridged a solder joint, unplugged something by accident or something else? Double check your work first of all. Do you still get high voltage? You may poor part. Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
How I can fix The Black&Decker digital advantage that does not heat
The iron will probably have to be taken apart.
If you are handy, you can do this when unplugged.
Check for broken connections and anything that is obvious like burned smell etc.
Feb 16, 2008 | Black & Decker AS150 Iron
Sport & Outdoor - Others Logo
44 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
