Watches Logo
A
Anonymous Posted on May 08, 2014
How can i start my watch again - Calvin Klein Watches
1helpful
My Watch has stopped after being in the dark for long. How do i get it to start again
I take it is a solar watch leave it in direct sunlight for a few days
If it is a Seiko kinetic wear it and it should start up again if not repair may be your only option to get it going again if possible
Jan 31, 2016 • Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
1helpful
How do I set my Timex 1440 sports watch
Press the MODE button.
Then hold and press reset/lap button for 2 seconds.
Press mode button again.
Press Start/Stop to set the Hour.
Press Start/Stop to set the Minute.
6helpful
2answers
Hi, My watch is changing date at 12 noon instead
Your watch is 12 hours out of step. (The date changes every second revolution of the hour hand.)
Wind your watch forward 12 hours, (you may have to reset the date) and it will then change around midnight.
9helpful
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
7helpful
How to reset time columbia small sport watch cl-5008
Press mode til you get to time then press and hold set. Once the hour starts blinking press the ST/SP button to set the time, then press set again for the minutes and do the same thing again. This should let you set your watch.
6helpful
Watch settings
Press MODE and it jumps to Timer. Press mode again and jumps to ALARM set. press MODE quickly and jumps to time set. press START/STOP to reset and press RESET to change to minutes or hours. press RESET again and changes to Date Set...
Sep 17, 2008 • Watches
3answers
Link Tiger Woods Limited Edition Number 398
The Battery might be dead. and if its a problem with the actual watch home repair might not be the best since its a nice watch. i would just take it to a watch repair shop and ask them. hope it was some help
2answers
Watch stops
sounds like the oil is contaminated and causing undo friction or the main spring is ether broken or slipping. Time to service your watch. call me 707-338-3207 www.finewatchmaking.com
Top Calvin Klein Watches Experts
k24674
ADMIN Andrew
ADMIN Andrew
Alex Kimuyu
Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
