How do I unstick a stuck reversing valve on LG split cycle air conditioner
Therinnaiguy
  • 1420 Answers
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Posted on Aug 30, 2007
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Posted on Apr 05, 2009
  • 99 Answers
SOURCE: 24000 BTUs LG split air conditioner external unit
Hi; Look into Your owners manual for troubleshooting codes. If You dont have a manual call or google the manufacturer...alpharome416
Posted on Jan 22, 2010
  • 81 Answers
SOURCE: Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
Is Conia air conditioner CA24001 split system reverse cycle I cannot get heat?
Sounds like either bad reversing valve or to get you going during the summer someone may have wired it to stay energized all the time which would have been a thermostat problem.
May 30, 2016 | Dometic Heating & Cooling
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
I'm a hvac technician myself looking for some advise
if it is a heat pump you could have a clogged actuator piston or a stuck reversing valve depending on whether the unit is energized in the heating or cooling cycle. Try pulling the wire on the reversing valve coil on and off a few times and that may force it to unstick. There is a lubricant that you can pour directly into the true suction line above the reversing valve itself. Supco oil is the name i believe. Also can try removing the actuator piston at both the condenser and the evaporator and checking to see if there is some trash in the line, especially if the lines were brazed without using nitrogen.
Jan 29, 2013 | Heating & Cooling
Have a LG Split -can't get it to heat. Air conditioner works fine, when I set the remote to heat all that happens is the blower works.
If it does not start heating after a couple of mins check change over valve and coil located in condensing unit if it's stuck on cooling sometimes you can tap it to free it but if it is sticking it will need replaced
Nov 23, 2011 | LG Heating & Cooling
Quiet air heatpump model qa18hrin1 is only blowing out cold regardless of what the temperature is set to
The reversing valve is stuck in one position and could indicate a bad valve or a bad control board.
Aug 01, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
5mint cooling 5minuts heating
The reverse valve and silenoied are bad, you need to change them or replace the condencer.
May 04, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Reversing valve not switching over to air on heat pump. compressor will come on for about 10 minutes, then shut off. Hot air comes out vent.
Look for any refrigerant leaks - no or low refrigerant can cause problems in both modes. The unit may be going off on low suction.
-OR-
The unit may be stuck in the heating mode.
Make sure the system is calling for the correct mode (cooling or heating) - some systems are auto, but if you can, select cooling since that is the requested mode. Check for power at the reversing valve inside the condensing unit. If power exists, then the reversing valve is stuck. It could also be the reversing valve solenoid coil, so make sure that isn't bad. There should be a strong magnetic field at the solenoid coil.
If you can hear the reversing valve clicking (moving), check the T-stat and make sure it will switch modes. Also check the reversing valve relay (those can be located in either the indoor unit or condensing unit).
May 25, 2009 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
