Question about Harman Kardon Audio Players & Recorders
When volume reach 40 it will shut down whats the problem
3 Suggested Answers
Jaycifer
  • 8 Answers
SOURCE: asus p320 turninf off/shutting down on 40% battery life
Pinstack.com will be able to fully help you with your delima
Posted on May 06, 2009
  • 990 Answers
SOURCE: Pump works fine but after sprinkler system is
You probally need a new pressure switch that mounts on or near your pressure tank and controls the pump.
Posted on Sep 03, 2009
Hii I have sony shake 6D system and whenever I turn the volume up it reaches upto 40 and shows the error of 'protect E01' while the maximum volume is 50. Please help
Most likely, your unit is shutting down due to overheating. You cannot run an amp at that kind of volume very long. It is shutting down to protect itself. Try running the amp at 1/3 your normal level. Most likely, it will not shut down.
Aug 05, 2015 | Sony Audio Players & Recorders
Amp shutting down when volume gets too high
Easy! You either have a surround speaker wired backwards or there is a break in the wire leading to a surround speaker that is allowing the +&- to arc together. your amp shutsvoff as a protection to keep the arc from reaching the mother board. replace your wires man!!
Nov 29, 2012 | Pioneer Audio Players & Recorders
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
Hi there, ive got a 4500 watt amp connected to the two 1500 watts subs i bridge the two subs and it sounds greater than any other sub that ive had before....BUT lately it starts to play up,the maximum of...
could have shorted coil, check resistance on each speaker and compare, should be rated @ 4 or 8 ohms, or disconnect both then run individualy to test output
Dec 30, 2009 | JBL GTO14001 Car Amp
Asus p320 turninf off/shutting down on 40% battery life
May 04, 2009 | ASUS Computers & Internet
Onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-DS575 Receiver
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Volume starts out at full
If you read the owners manual careful it tells you something about setting the volume at start up buy setting the volume to desired level then push in and hold a few seonds the volume knob and that volume should be reached every time you start your vehicle.
Oct 12, 2007 | Dual XDVD8181 Car Video Player
Receiver Shutoff
That may be a clue to your shutdown problem. Disconnect that speaker and see if the unit still shuts down. If it does not, then there is a problem with this speaker,or the wiring going to this speaker. If the unit still shuts down, disconnect each speaker at a time to see where the problem is. If none of the speakers seem to cause the shutdown problem, there is na major fauly in the amp circuit, so the amp will need serviceing or replacement. Good Luck
Apr 08, 2007 | Kenwood VR-4090 Receiver
19 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
