Question about Toymax GPS
All power apg3102c parts
I need ignition kit (coil and trigger circuit) for this generator. fezeilo@yahoo.com
  • 61 Answers
SOURCE: upgrade kit part: TV-3940-01 - But the part is backordered for three months. $150.00
I beleive this comes directly from manufacturer.becasue thsi Kit cotains a upgraed E-prom.
before you order any kit check it this unit has been upgraded before? if this unit upgraded before you dont need to change kit again.
I would say either y-sus or z-sus could be the problem..
Good luck
Dals123
Posted on Oct 09, 2008
  • 191 Answers
SOURCE: I have a first generation
Okay...when you say power to the coil...I think you mean getting a spark on the plug wire?
All 4 coils should have battery voltage on the red/white wire to each coil. The second wire returns to the igniter (TCI....ignition black box) and it switches that wire off and on to ground to cause the coils to fire. If all 4 test good...then
Check out the TCI, the large box mounted on the coil rack that the connectors are clean.
Now remove the 6 wire connector from the TCI...and test the resistance of the pickup coils which are located under the left crankcase cover beside the stator coil.
you will be testing the following wire pairs on the 6 wire connector
Orange-Black
White/Red-Black
Gray-Black
White/Green-Black
You should see at ambient engine temp...about 110 ohms resistance on all 4 pairs.....if one pair is showing no resistance...you need to test at the lower 5 wire connector just below the seat left side with the same 5 colors....unhook and test....if still having one bad test...pickup coils may be bad.
Posted on Apr 10, 2011
alicantecoli
  • 22326 Answers
SOURCE: i have a 1967 VW-Datona Migi ( Kit Car ) on
look its getting late in this time zone and iam tired so please post a reply as to exactly what you need as i think this is a flat four beetle engine ,and i need to know if it has points or a ignition module ,alternator or dynamo so take your time and reply with a camera picture or two if possible and then when i finish work tomorrow i will answer to teh best of my ability as this sort of engine is ancient and modern mechanics wouldnt know unless they can plug it in .
Posted on Sep 07, 2011
little_shaws
  • 493 Answers
SOURCE: HOW TO DIAGNOSE AND TEST IGNITION SYSTEM AND COMPONETS ON A 2001 ISUZU TROOPER 3.5 LITTER V6 ENGINE
I would start with the crank angle sensor.
Posted on Jun 25, 2012
ZJLimited
  • 17970 Answers
SOURCE: code 0300 ,0303,0351,and2302
Hi there:
DTC P0300 - RandomMultiple Cylinder Misfire Detected
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Symptoms may include:
the engine may be harder to start
the engine may stumble / stumble, and/or hesitate
other symptoms may also be present
A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Possible Solutions:
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
DTC P0351 - Ignition Coil A Primary/Secondary Circuit Malfunction
The COP (coil on plug) ignition system is what is used on most modern engines. There is an individual coil for each cylinder that is controlled by the PCM (powertrain control module). It eliminates the need for spark plug wires by putting the coil right above the sparkplug. Two wires are dedicated to each coil. One is a battery feed usually from the power distribution center. The other wire is the coil driver circuit from the PCM. The PCM grounds/ungrounds this circuit to activate or deactivate the coil. The coil driver circuit is monitored by the PCM for faults
If an open or a short is detected in the driver circuit for coil number 1, a P0351 may set. Also, depending on the vehicle, the PCM may also shut down the fuel injector to the cylinder also.
Symptoms of a P0351 DTC may include:
MIL (Malfunction indicator lamp) illumination
Engine misfire may be present or intermittent
Potential causes of a P0351 code include:
Short to voltage or ground on COP driver circuit
Open on COP driver circuit
Loose connection at coil or broken connector locks
Bad Coil (COP)
Faulty Powertrain Control Module
Possible Solutions:
Is the engine misfiring presently? If not, the problem is likely intermittent. Try wiggle testing the wiring at the #1 coil and along the wiring harness to the PCM. If manipulating the wiring causes the misfire to surface, repair the wiring problem. Check for poor connection at the coil connector. Verify the harness isn't misrouted or chafing on anything. Repair as necessary
If the engine is misfiring presently, stop the engine and disconnect the #1 coil wiring connector. Then start the engine and check for a driver signal to the #1 coil. Using a scope will give you a visual pattern to observe, but since most people don't have access to one there's an easier way. Use a Voltmeter in AC Hertz scale and see if there's a Hz reading of between 5 and 20 or so that indicates the driver is working. If there is a Hertz signal, then replace the #1 ignition coil. It's likely bad. If you don't detect any frequency signal from the PCM on the ignition coil driver circuit indicating the PCM is grounding/ungrounding the circuit (or there is no visible pattern on the scope if you have one) then leave the coil disconnected and check for DC voltage on the driver circuit at the ignition coil connector. If there is any significant voltage on that wire then there is a short to voltage somewhere. Find the short and repair it.
If there is no voltage on the driver circuit, then turn the ignition off. Disconnect the PCM connector and check the continuity of the driver between the PCM and the coil. If there is no continuity repair the open or short to ground in the circuit. If continuity is present, then check for resistance between ground and the ignition coil connector. There should be infinite resistance. If there isn't, repair the short to ground in the coil driver circuit
NOTE: If the ignition coil driver signal wire is not open or shorted to voltage or ground and there is no trigger signal to the coil then suspect a faulty PCM coil driver. Also keep in mind that if the PCM driver is at fault, there may be a wiring problem that caused the PCM failure. It's a good idea to do the above check after PCM replacement to verify there won't be a repeat failure. If you find that the engine isn't misfiring, the coil is being triggered properly but P0351 is continually being reset, there is the possibility that the PCM coil monitoring system may be faulty.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Posted on Jun 29, 2012
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Dec 05, 2015 | 2001 Cadillac DeVille
No spark,new spark plug &coil,what else can it be
Check the power supply to the coil. If the primary winding isn't getting power then the magnetic field it generates can't collapse to trigger the high voltage pulse put out by the secondary winding.
Mar 04, 2015 | Cars & Trucks
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Gentrax 4.4 kva generator looses spark above idle. goes anyone have a wiring diagram???
Itr sounds like a failing ignition module, or incorrect trigger gap
Oct 22, 2013 | Electrical Supplies
98 mercury villager no start , code P 1320
Here is the entire description for the code -
When is the code detected?When the ignition signal in the primary circuit is not sent to Engine Control Module (ECM) during engine cranking or running.
Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
P1320 NISSAN Description The ignition signal from the Engine Control Module (ECM) is sent to and amplified by the power transistor. The power transistor turns on and off the ignition coil primary circuit. This on-off operation induces the proper high voltage in the coil secondary circuit
Possible causes - Faulty power transistor unit built into ignition coil
- Ignition primary circuit is open or shorted (circuit to ignition coils)
- Ignition primary circuit poor electrical connection (circuit to ignition coils)
- Faulty ignition system condenser
- Crankshaft position sensor circuit
help.png Help with this Tech notes The most common cause that will trigger the P1320 code is the ignition coils, one or more ignition coils may have failed. Even tough the coils may be working OK, the resistance for one or more of the coils is greater or smaller that what the Engine Control Module (ECM) is expecting. Measuring the resistance with the coil out of the vehicle may not show any failures, usually the coil fails under heavy conditions (hard acceleration) or certain temperatures.
The P1320 code means that there is problem with the "Ignition Coil" or the wire to the ignition coil. For some models without individual ignition coils the Ignition Coil is inside the distributor and the distributor need to be replaced to fix the problem.
Read more: http://engine-codes.com/p1320_nissan.html#ixzz2EJsrz4BZ
Read more: http://engine-codes.com/p1320_nissan.html#ixzz2EJsktmXX
Dec 06, 2012 | Cars & Trucks
My kohler 5000 generator will not run unless I keep the starter button depressed
First thing to do is get a "Wiring Diagram" for your Unit.
Once you get the diagram, just Follow the DC Ignition Power path from
the Battery, on thru to the Ignition Coil. Somewhere you aren't getting
12Vdc to the Ignition Coil, UNLESS the Start Switch is in the Start Position. It shouldn't take longer than about a hour, with a VoltMeter to find where the circuit isn't being "Made", and fixing or replacing that part. More solutions to different engine and generator problems at http://solosmallengine.blogspot.com/ and http://solo.ecrater.com
Jun 07, 2012 | Electrical Supplies
Miele LP cooktop: we turned the power to the range off. when we turned on again it didn't ignite (it has power!)
Hello
Keep the air holes around the burners free of debris and grease by clearing out the holes with a thin piece of wire or a toothpick. Cleaning out the holes helps the ignitor light the cooktop
Listen for the clicking sound of the ignitor, then turn off the burner if you don't hear the clicking.
Turn the burner to the "Off" position, if you continue to hear the ignitor tick after you've lit the burner. Turn the burner back on to relight it. Ignitors normally make a brief series of electrical clicking sounds when you turn on the ignitors.
Let the ceramic igniter dry out if it has gotten wet and the burner won't ignite. If the igniter isn't wet, clear out the little holes in the burner by chipping out any blockage with a straightened paper clip.
Clean the electrodes if the burners still don't light. The electrode is in the burner base. Clean the metal part with a soft cloth. You can use emery board on the metal part but not the white ceramic part.
Nov 03, 2010 | Miele 30 in. KM443 Electric Cooktop
Ignition coil spark is weak. And where can i find
FIRST check the gap of the flywheel magnet to the magneto coil. Use a business card as a spacer and adjust the gap. If unit has points rather than electronic triggering, check those and timing and gap.
Mar 22, 2010 | Coleman Powermate Premium Plus 6250W...
95 s-10 runs perfect but has no power at all
the second code is generated by the first... since you have spark issues it causes the truck to run lean which in turn causes the lean exhaust code to show up... check your ignition coil, plugs and plug wires... your problem is more than likely in one of if not all of those areas...
Jan 06, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Truck will not start
The vehicle will have a solid state ignition system. Distributor,control unit, pulse generator and ignition coil. The distributor is basically the same as in a conventional (Kettering System) car ignition. The difference is that the capacitor and breaker points are not used. Instead these are replaced by a pulse generator, consisting of a reluctor which rotates with the distributor shaft, a stator and a pick-up-coil mounted on the distributor base plate. There is no contact between the moving parts. The #1 suspect would be the control unit, which is a discrete non-adjustable electronic switching device which determines the period wduring which current will flow in the primary circuit. (i.e. 'The Dwell Angle") The control unit ALSO controls and interrupts the primary circuit when triggered by pulses from the oulse generator. (This induces current to flow in the secondary circuit) Take note that the ignition coil is a special design and should NOT be replaced with a coil from a conventional car ignition system. You should check continuity between all the wiring connections linking the coil, distributor and the control unit. Make sure that earthing points are effective and clean. Check that there is a proper connection between the distributor + and the control unit and esspecially the connections on the coil. Sometimes the vehicle ignition switck can be faulty but it is rare that it is so. The risk is if you do not know what you are doing, you could damage the solid state circuitry in the control unit. Check also the distributor cap, the ignition coil HT lead, see if you can get a spark whilst someone cranks the engine over. The testing procedure is too long to describe here. But email imsuze56@gmail.com for detailed information if you need it.
Jun 12, 2008 | 2001 Chevrolet S-10
GPS Logo
32 people viewed this question
Top Toymax GPS Experts
Tre Elkins
Will Halftowaite
Are you a Toymax GPS Expert? Answer questions, earn points and help others
