Question about Cell Phones
Samsung Galaxy 3...What are the most common problems caused by getting it wet? Samsung Galaxy 2.... not charging the battery? Samsung Assend.... getting it wet?
  • 111 Answers
Search youtube for your best results
Posted on May 08, 2014
toy_ladi
  • 484 Answers
SOURCE: Battery depleting way to fast
The cause is that the phones battery terminal head is faulty so it is draining the battery.
The terminal head is the metallic link that connects the battery to the phone.
The terminal is also connected to the board of the phone, so to fix this, you have to be very careful as it requires you soldering some components on the phone.
Get the appropriate screwdriver, unscrew the phone,use a flat object and apply a little force on the line that goes round the phone to split it open.
You will see the terminal as it is connected to the board of the phone, carefully use a pin tip soldering iron to remove the terminal head, then replace it with the new terminal head you acquire for it.
Ensure you do not tamper with the board of the phone.
Couple the phone back together, and turn it on with a fully charged battery.
Take care
Posted on Jun 15, 2010
  • 326 Answers
SOURCE: I have Samsung Galaxy 5 GT-15503. Android 2.1.
Wi-fi has been known to eat up the battery life on ALL devices it's on.
That's just the way it functions.
If you really want to save battery on your phone, disable wireless, bluetooth and 4G connections you may have, dim the screen to it's lowest setting and change the display timeout to a very low time.
Posted on Mar 10, 2011
  • 11 Answers
SOURCE: My samsung galaxy nexus doesn't always charge when
please book your complaint to service center
Posted on Apr 28, 2012
basil_i_50
  • 3 Answers
SOURCE: samsung galaxy 2 won't start, no feedback when charging as well.
Do you have root ?
Posted on Aug 20, 2012
awaissabair
  • 580 Answers
SOURCE: My galaxy ace got wet and now won't charge what can I do
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 03, 2012
What is the most likely reason a Samsung gear 2 neo touchscreen would be unresponsive to turn on and off
If your Samsung Gear 2 Neo refuses to turn on:
1. the first thing I would suspect is a dead battery
2. If it does not showing charging when connected to the charging cradle:
A. it could be either a bad charging cable, wall adapter, cradle, bad battery, or the internal charging connectors.. Do a process of elimination only with OEM Samsung cables and charging adapters.
Note: the Samsung Smartwatch charging cradle is not normally sold in stores, so if you lost it contact Samsung support to get another one [1+(844) 454-5925], or download the Samsung+ app from the Google Play App Store to access Samsung Support contact information
B. If the Smartwatch has been on the shelf for a long time (either in store or not used after a long time) the battery will deplete itself so low that it needs to be trickle charged for 10 hrs or less depending on how dead the battery is.. Rather than being put on it's regular charge adapter for a few. Try inserting the charging cable into a computer USB port instead of into the wall charger adapter (see attached video)
3. If the Smartwatch is on, but won't turn off:
A. it may be a software issue.. Like an app you installed is clashing with another, or maybe an update got corrupted by a bad bandwidth connection.. If this is the case reset the watch and start over.
B. It's possible you have too many things going on and all the RAM memory (the brain) not storage space, has been used up.. Which is a temporary crash, just like when you over load your brain with too much stuff at one time..
Samsung Galaxy Gear not working
Dec 20, 2015 | Samsung Cell Phones
Samsung Galaxy S2 wont turn on or charge, it also wont let me do the Hard Reset,is this fixable?
May be the problem is in the battery try replacing with a new one, the battery problem is very common in samsung devices.
Apr 17, 2015 | Samsung Galaxy S2 S II I777 AT&T
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Jul 24, 2014 | Samsung Galaxy Tab 2
Samsung galaxy s2 will not charge
Could be a battery problem, ut is usually a problem with the charge cable or connector. Try a different charge cable, they are usually Micro USB connectors, and check if the power (MaH) Matches what your phone needs. Otherwise you might need to repair the port. Try this.
http://www.youtube.com/watch?v=q4e-5xkhvHA
Jul 22, 2014 | Samsung Galaxy S Ii 2 Sgh-t989 16gb...
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Where can i get my galaxy s charging port fixed and how would the port become loose?
If it's loose it is probably broken away from the internal circuit board. A common problem. People accidentally knock the plug sideways and they only have fragile connections.
Get a technician to resolver if possible or take to Samsung repair centre.
May 02, 2014 | Accessory Export Samsung Galaxy S i9000...
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
My samsung galaxy tablet is not coming on and i am still charging it
I'd suggest you disconnect the battery, wait for ~3 minutes, connect the battery again and try booting the tablet once more.
The problem could either be a hardware issue or a faulty OS, the latter meaning you should factory reset and reinstall the tablet.
Samsung Galaxy Tab 2 7 0 Battery Replacement
Jul 01, 2017 | Samsung GALAXY TAB 2 7.0 8GB BLACK P3100,...
Instructions for Samsung galaxy s3 charger
It should show green light. Its nice phone and I have used this and never had any issue like this. You can also check at Samsung India site in support option. May be you can get some help from there.
Samsung Galaxy S3 Price India Buy 3 Smartphone Features Reviews Specs
Dec 27, 2012 | Samsung Galaxy S3 S III Spare Battery...
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
