Question about eMachines eME720-4691 Notebook
Mouse path lap top mv4 - eMachines eME720-4691 Notebook
I have got toshiba lap top, it's mouse works in
Please boot in safe mode and click on start menu and type system restore. and open the system restore and select old restore point and restore it. After the restoring system will restart.
Aug 02, 2011 | Toshiba Computers & Internet
Mouse 98812 does not work. when I plug receiver into my computer it makes a sound as if the computer recognises it but the mouse woun't move the pointer. Thanks cloader66@aol.com
Make sure that the batteries are changed out then try it again if that is not the case and the batteries are all good then make sure that the distance is within range or nothing is in front of the receiver like a cell phone or a phone or anything like a lap top have nothing in the path that is electronic I do hope that this assisted you if so please post a good vote for me thanks for using FixYa! John
Apr 07, 2011 | GE Wireless Optical Mouse
My lap top mouse orange light is on and i can not use the mouse pad on lap top
look closly to the mouse pad usually around it may has a botton click on it
Sep 25, 2010 | Computers & Internet
Put wireless mouse on a pavilion dv6 3031tx lap top and it worked fine then the other day lap top batters went flat and now mouse will not move pointer yes it still installed and working correctly have...
Please uninstall the whole driver package and also clean the registry fo the software via START--RUN--REGEDIT- and re-install the same. It would work FINE
Sep 01, 2010 | Microsoft Wireless Mobile Mouse 3000
Mouse quit working on my Lap Top it is a Aspire
First of all check whether the touch pad is lock (Fn+F7(?)). If you use an external mouse/ usb mouse, check usb cable connection, as long as you didn't drop it on the floor it should be ok. If the built in touch pad doesn't work, could be caused by ribbon cable connectivity that has dirt or moist. To fix it need to open the upper case
Apr 08, 2010 | Computers & Internet
My mouse on my compaq lap top is terrible The
hello,
Please reinstall the touch pad drivers once and if then also it is not working the needs to be replaced.
Thanks
Dec 10, 2009 | Compaq Presario Notebook
Lenovo N500 lap top - mouse is inactive. Need
Some laptops have a key sequence to activate or disable the onboard touchpad.
Look for Fn+F8(or another combination) the key should have a mouse symbol on it.
May 11, 2009 | Computers & Internet
I have a new optical USB mouse but the windows vista on my lap top did not recognise it it sea it but need driver to install it i tried every sing on the lap top to find solution but failed regarding i...
Usually Vista does not need driver to install an USB Mouse.
Try this:
Turn off the laptop, then put the mouse connection. Turn on again. See if now it is working. The mouse should be connected in "off"
If still does not work, try put in other USB port of the laptop. Usually a laptop has at least 2 USB port. Remember to connect it always in "off".
Apr 03, 2008 | Computers & Internet
Mouse on lap top dosent work
Can you tell me the model of laptop you have? Have you checked the settings in the control panel?
Nov 30, 2007 | KEIO PS2 Optical Scroll Mouse
eMachines eME720-4691 Notebook Logo
12 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
