Question about Navman Trackfish 6600 GPS Receiver
I put a new cmap card in my 6600 sounder but it wont give me a picture ?
Why can't I get picture or sound when my Sound Bar, TV and Blu-ray player are connected?
You have to run an audio cable from the TV to the sounder and put the sounder on the TV input for sound to work. The first choice audio cable for best sound would be optical cable if your tv has optical output on it. If it does then you would put the sounder on the din input for sound when watching antenna or any hdmi source connected directly to tv. If your TV only as analog rca out or mini audio out then put sounder on aux input. I think your sounder came with mini to mini stereo cable. If your TV doesn't have mini audio out the get a optical cable or you can find a mini to rca red/white will work. Optical is your BEST connection and soundbar would stay on din all the time for best sound.
Feb 10, 2015 | Vizio S5430W-C2 54-Inch 3.0 Soundbar Black
Back up sensors
put it in r with ign on put your ear on each sensor close to each sensor in turn they should make a faint clicking sound any that dont could be faulty, does the sounder give a error tone? if not the sounder may be faulty.
Oct 14, 2013 | Jaguar XJ8 Cars & Trucks
Nokia 6600: Bluetooth wont open
solution for 6600 bluetooth and gallery cannot open
step 1) make a jumper (you can see the encircle terminal of bluetooth ic) then assemble the mobile,turn it onstep 2) OPEN FIRST THE GALLERY WITHOUT MEMORY CARD,THEN OPEN ALL THE IMAGES,MUSIC ETC. INSIDE OF YOUR GALLERYstep 3) TIME TO TURN ON YOUR BLUETOOTHstep 4) PUT BACK THE MEMORY CARD AND DO 2 AND 3step 5) then remove the jumper and do step 2,3,4..if still the cannot open again,put the jumper and reheat the bluetooth ic and repeat it step 1,2,3,4.I ..GOOD LUCK TO ALL WANT TO TRY! JUST TRY IT THERE IS NO RISk
Mar 17, 2011 | Nokia 6600
Hi my nokia 6600 cant access to memory card and appears "memory overloaded" while taking pictures. please suggest
you'll have to delete some old stuff (mms, sms messages, pictures, videos..) Your memory is full and it needs some small amount to operate and store new pictures and other data
Feb 28, 2011 | Cell Phones
My geforce 6600 wont give a signal when used with this mobo, why?
Open you're manual to page 2-22. Make sure, Booting Graphic Adapter Priority is set to:
[PCI Express/Int-VGA]. Save and exit the bios. You're system will auto reboot. When you're screen goes black, press and hold the power on button until you're system shuts off. Install the 6600 video card. Double check the 6600 card. Most PCI-E cards need additional power connected to it to run.
If you need the manual you can open the link provided; http://dlcdnas.asus.com/pub/ASUS/mb/socket775/P5GD1-VM/e1881_p5gd1-vm.pdf
Hope you find this helpful!
Cheers'
Mike
Mar 27, 2010 | ASUS P5GD1-VM Motherboard
I need a manual for Navman trackfish 6600
I need a manual for a Navman Trackfish 6600. Can i download it or where can i purchase it from?-
Dec 30, 2008 | Northstar Explorer 660...
Nokia 6600 chellphone
try to remove your sd card and open it in a pc using a card reader... there you can copy the files and transfer it to other disk... maybe its almost full.. make a copy of everything and format your sd card. this will give you more space. 6600 slows down if the memory card is loaded try to remove other files especially large files. a full sd card slows down the cp's performance...
Aug 26, 2008 | Nokia 6600
Changing com port numbers??
Some (older or less sophisticated) software expects a com port with a number no higher than 4.
If this is the case, try changing the GPS emulated / virtual com port in "windows | control panel | system | ports" to something less than 5.
Jun 18, 2008 | Linksys Wireless-G WRT54GS Router...
Nokia 6600
Check the SIM COTROLLER IC, if the IC is OK the upgrade SOFTWARE.
Supriyo DG
May 29, 2008 | Nokia 6600
Navman Trackfish 6600 GPS Receiver Logo
22 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
