Question about Minolta CF2001 Copier
Cf2001 will not allow use of copier
Copiers unit will not allow selection of copies or use of b&w or color copies, or allow setting of number of copies...
  • Minolta Master
  • 6,696 Answers
I assume you unplug the machine, does it have a internal fiery? have you open and close the front door, Also check user settings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 12, 2009
Cf2001 fuser jam
What to do or the part number or the what do you need? When printing or copying? which draw are you using double sided or single?
Feb 11, 2013 | Minolta CF2001 Copier
How to change the power on default copy mode form color to black & white.
Hello Gary
On the main copy display your device is probably set to the factory defaults which means that when you press reset the device is in "AUTO COLOR". Touch the "AUTO COLOR" tab on the screen and a drop down menu will show. Select "BLACK AND WHITE". Now press the "ADDITIONAL FUNCTIONS"key. Select COPY SETTINGS located at the top right. Scroll down till you see STANDARD SETTINGS and select it. Press STORE. You are fixed!!! Please let FIXYA know I helped. :-) SPINAL
Jun 17, 2011 | Canon imageRUNNER C3380i Color Copier
How to change the default power on copy mode from color to black & white.
I'm not familiar with this particular model but if it's like the IR color copiers this should help you. First select the black mode for the copier, Then press the additioanl function key, then copy settings, then look for standard settings. I can't remember if you have to use the arrow keys at the bottom to see this. Anyway select standard settings, then STORE, then then confirm these are the settings you want then YES. Press reset and see if the settings are what you wish.
How to set the default copy mode on a Canon irc3380 so that it starts up in black & white copy mode rather than color?
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Jun 16, 2011 | Canon imageRUNNER C3380i Color Copier
Where can I find a Fiery unit for my CF2001 minolta copier?
I have a used one - contact me @ advantagecopies@yahoo.com and will discuss
Jan 12, 2010 | Minolta CF2001 Copier
Copier will not operate
May want to check that default setting have been set for number and black and white, utilty then default settings reset to factory
Jun 22, 2009 | Minolta CF2001 Copier
CF2001 w/Fiery X3A and scanner resolution
How is the scan resolution changed when using the Scan to HDD feature?
Solution
Press the scan button and then press the clear key on the copier control panel. Enter the desired resolution from 1-600 DPI.
Mar 18, 2008 | Minolta CF2001 Copier
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Minolta cf 2001 c13cc service code
c13cc is a code calling for a new oil coating unit. Minolta Part# 4697-151. We sell a rebuilt unit for $ 39.95. Sales Phone Number 608 884 2277 ask for Aaron.
Oct 13, 2007 | Minolta CF2001 Copier
48 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
