Hi I have two HP 2009v monitors that have - Computers & Internet
Hi I have two HP 2009v monitors that have previously been working fine, all of a sudden, after turning the base unit on windows Xp shows the, monitor lights are on but the screens show blank, do you know of any cause & resolution? Thx
  • 528 Answers
I had this issue with my HP monitor too. Turn on pc and look at the monitors with light shining on them - you'll probably see the images, which indicates they illumination portion of the monitor board burned = much cheaper to replace!! You did not mention if they are L.E.D., but I'm almost willing to bet they are - and over 3 years old too, huh? Sorry for the bad news - hope this helped!!
Posted on May 08, 2014
    Scholar:
  • 114 Answers
Sounds a lot like something went wrong on the Power supply/data stream to the screen..... If all the lights are ON but nothing on the screen.... then I suggest new Monitors as these would probably cost more to fix over new Monitors.
  • ARIIGWE May 08, 2014
    Thx Rick will bear it on mind
SOURCE: Mag innovision LT716s monitor model 700p blank screen
Have you installed the drivers for it? I had the same problem and when I installed the driver, problem solved.
Posted on Mar 02, 2008
tantong
  • 138 Answers
SOURCE: Blank ACer X221W Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went dim and blank, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Mar 06, 2008
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 788 Answers
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Posted on Sep 03, 2009
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
SOURCE: hp w2207h screen in blank but flashlight shows icons are
The power supply-inverter board is probably at fault. Remove the back cover and locate the standard ac power cord connector. The board that the power input connector is soldered to is your power supply - inverter board. Check the electrolytic capacitors on the board. They probably went bad. A visual inspection is usually enough to find out which ones are bad. They will be either bulging or cracked at the top and leaking fluid. I usually replace all of the capacitors that have the same rating whether they look bad or not. Will save you another repair later. If the caps don't look bad, you can take the board to your local tv repair shop and have the caps checked with a esr tester. It's more accurate and they can be tested with the caps in place. Hope this helps.
Posted on Mar 08, 2010
Have LG W2343 monitor. Just purchased a new HP computer which has Windows 7, but having trouble with the size resolution on my screen. Monitor worked fine on my old HP computer which had Windows XP
You have to look hereto see if it is compatible with Windows 7,
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Browse.aspx?type=Hardware&category=Displays&subcategory=LCD&showallcats=true&v=LG%20ELECTRONICS
Otherwise you will need Windows 7 driver from LG if they have one.
Most monitors works fine without the need of the drivers when running XP, but Windows 7 you need the correct drivers to get the correct resolution setting, that is one of the reason I do not care much for Windows 7 until they fix this problem, since a lot of people out there that still have great working monitors that work just fine with XP, most manufacturers do not provide drivers for Windows 7 for old monitors because they want you to buy new monitors.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 04, 2011 | LG Computers & Internet
Suddenly, the handheld monitor turns off (no picture or sound) and will not turn back on, even when I plug in the AC adapter. The green light on the battery indicator is on, but the monitor won't turn on...
Mine jut did this. What did you end up doing. I did what other people said which was take the battery our and put it on the stand... NOPE... green light on but not sound or picture. I could hold the button down until the cows come home and it will not turn on.
Sep 23, 2010 | Summer Infant Slim Secure Handheld Video...
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Computer monitor becomes distorted after boot up.
Download and install the correct driver for the monito as well as the deiver for your video card, if the video is onboard, you may need the motherboard and AGP driver as well.
You will probably need to boot in Safemode to do this.
Good Luck.
Feb 10, 2009 | HP Computers & Internet
Audio Driver
You need to post the model # of your pc, as the monitor is not the problem...
Apr 02, 2008 | HP Compaq FS 7550 17" CRT Monitor
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
