Question about Toshiba Portege M200 Tablet PC
Local user and password for portege - Toshiba Portege M200 Tablet PC
When i turn my p3500 on it ask for password and i want to get it off. pls help me
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Dec 13, 2012 | Toshiba Portege 3500 Tablet PC
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
How to reset toshiba portege 3500 laptop password from bios
first remove the bios battry romove the mb memori ic 24c small 8 pin 3 and 6 to conat wire solder short wire power on you bios lock unlock be care full to work power on time.
Feb 22, 2012 | Toshiba Portege 3500 Tablet PC
Hi I have a toshiba portege m750 and my little brother was using it and I have decided to use it for college but the only thing is he cannot remember I was just wondering how would I go about changing the...
You can set a user password from inside Windows. From the configuration panel look for an icon that represents two persons and click on it. Follow instructions on setting a user password.
You can also set a password on boot but you have to be careful: If you forget it you cannot open the tablet to remove the password. You will need to take the computer to a Toshiba Certified Service Center.
To set the password on boot you can use the BIOS SetUp configuration or a Toshiba Windows applications (HRWset).
For Windows XP tablet PC edition 2005
If you have the CrossMenu application you can run the HRWsetup from there. You can also go to All programs, Toshiba Utilities and look for HRWSetUp.
For Windows Vista or Windows 7, the name of the application may be Toshiba Security Assist.
Be very careful. You must not lose the password
Jul 30, 2011 | Toshiba Portege M700-S7002 Tablet PC
I have a toshiba portege model 3505 that has a password at bois i cant remember my password how do i get in to my bois
That BIOS-password exists to protect you, should a thief gain posssession of your computer.
Find your original sales-receipt, to prove that you are the rightful owner, and telephone Toshiba.
Ask for Technical Support -- they can help you "nullify" that BIOS-password.
Feb 12, 2011 | Toshiba Portege 3505 Tablet PC
How do I unlock my Toshiba Portege 3500 Tablet PC at motherboard password
If you want the fast way, then probably you have to rely on a third-party software. Take a try this password recovery software, it should help clear and reset the lost password and bypass the locked computer.
Note: you can do this on your own, no need to send the PC to anybody for any repair because it's dangerous for your private information stored on the computer, best regards.
Mar 09, 2010 | Toshiba Portege 3500 Tablet PC
Cannot log into windows I do not know the password I bought the laptop used and it never logged out before and asked for the password which I do not have. I cannot get passed the log in screen.
ok hold f8 when you boot it and go to safe mode then you can just change the password or set up a new user account and make your own password
Nov 30, 2009 | Toshiba Portege 3500 Tablet PC
Don't know how to get rid of hard drive password on toshiba lapto
A hard drive password can only be removed by the person who knows the password because then it can be cleared thru the BIOS.
Otherwise the only other way around it is the buy a new hard drive so it doesn't have a password and you can then reinstall the operating system on the hard drive and then put the drivers on it and any other programs that you want on it.
Apr 07, 2009 | Toshiba Portege M200 Tablet PC
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba Portege M200 Tablet PC Logo
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
