Question about Intel D845GVSR Motherboard
WHERE an i find pin placementb for this board
    Sergeant:
  • 240 Answers
What "pin" replacement are you talking about? Give details.
Posted on May 09, 2014
Can I interchange a 20 pin wire to 16 to 14?
You need the correct board when ordering replacements you need to quote all the numbers on the original often on a separate sticker on the board as there are often many versions with same board number
Feb 11, 2016 | Samsung Un46d6000 46 1080p Led Tv...
How do I add pins to my Pinterest boards?
  1. You can save Pins you find on Pinterest or add new ones from your favorite websites. Hover over a Pin you want to save and click Pin It. Or, click the Pin to see it close up and click Pin It. Choose a board for yourPin and add a description.
Dec 02, 2014 | Pinterest.com
Picture colors keep fading
U have tools like a soldering iron and roll of solders?Fixed it by resoldering the tv video board pins connecttions sockets pins between tv video board and the CRT-(tv tube). Tv video board that the board where it is connected to the CRT-(tv tube).The video board sockets hole pins that connected to the CRT-(tv tube).Those video board sockets pins are coldsoldering resolders this video board socket pins to the CRT-(tv tube).Will fixed thiss video colors fading problems.
Jun 27, 2011 | Symphonic ST419E TV
No picture and red light flashes about five times, pauses, then starts flashing again
Disconnect
CN SC20 on the SC board. Turn on the unit. Does the power LED
stay on?
Yes
SC
Board
No
Connect
CN SC20. Disconnect
CN SS23 (*1) on the SS board. Turn on the unit. Does the power LED
Stay on?
Yes
SS
Board
No
Connect SS23 (*1).
Disconnect CN D31and D32
on the D board. Is pin 5of CN P25 shorted
to GND?
Yes
Disconnect
CN P25. Is pin 5 of the socket P25 shorted
to GND?
Yes
P
Board
No
D
Board
Connect D31
and leave D32 disconnected.
Is pin 5 of CN P25 shorted
to GND?
Yes
Disconnect CB1-CB4.
to GND?
Yes
No
C1 Board
Panel
No
Yes
No
D Board
Disconnect CB1-CB4.
to GND?
Yes
No
C1 Board
Panel
Disconnect D31.
Connect D32.
Is pin 5 CN P25 shorted
to GND?
Yes
No
Disconnect CB5-CB8.
to GND?
Yes
No
C2 Board
Panel
Dec 18, 2010 | Panasonic TH-50PX75U Plasma HDTV
Electric on motherboard
Yes. usually. Most boards have pins missing. The board layout is for all boards,not all models. That is the reason that sometimes pins are missing. You will see layouts for other items(options) missing also.  Ido not have A drawing or picture of your particular board  though.
Feb 05, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
What are the pin conections for external usb on an asus a7v400-mx board
USB mouse/keyboard to 5-Pin DIN or 6-Pin Mini-DIN adaptor USB Function 5 Pin DIN 6 Pin ps/2
Pin 1 +5V Pin 5 Pin 4
Pin 2 -Data Pin 2 Pin 1
Pin 3 +Data/clock Pin 1 Pin 5
Pin 4 Ground Pin 4 Pin 3
shield shield shield
Apr 16, 2008 | Computers & Internet
Panasonic Th37PE30 Viera plasma stopped working
here is a complete list of all codes for panasonic tv's rgeardless of model if its panasonic it is these codes
1 Blink SOS: This shutdown operation is usually caused by a lack of communication between the A and the D boards.
1 Blink SOS: This shutdown operation may be caused by the improper connection of a SS board connector to the panel.
2 Blinks SOS: Pin 87 of the MPU IC9003 monitors the 15V line. During normal operation, the transistors Q9053 and Q9054 output a high to pin 87. If the 15V line is missing or shorted, a low is provided to pin 87. As a result, the unit shuts down and the power LED blinks 2 times.
3 Blinks SOS: IC9807 is a 3.3V regulator located on the D board. Its output is monitored by IC9003. If the 3.3V is not present at pin 86, the MPU shuts down the unit. The power LED blinks 3 times.
5 Blinks SOS: Pin 85 of the MPU IC9003 monitors the 5V line. During normal operation, the transistors Q9051 and Q9052 output a high to pin 85. If the 5V line is missing or shorted, a low is provided to pin 85. As a result, the unit shuts down and the power LED blinks 5 times.
6 Blinks SOS: Pin 90 of the MPU IC9003 monitors the status of the SC board. During normal operation, the transistor Q6581 and IC6581 output a low to pin 90. If the SC board becomes defective, a high is provided to pin 90. As a result, the unit shuts down and the power LED blinks 6
6 Blinks SOS: 6 blinks of the power LED may also be obtained from pin 3 of IC9003, the DRV_RESET input. The D board provides the 5V source needed to power the C boards. On the C2 board, the 5V is routed back to the D board via connector C20/C10, C11/D31 causing pin 3 of IC9003 to be high. If 5V is not routed back to the D board, pin 3 of IC9003 goes low. The set goes into shutdown mode and the power LED emits 6 blinks.
7 Blinks SOS: Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
8 Blinks SOS: Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
10 Blinks SOS: The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS: The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
Feb 26, 2008 | Televison & Video
Panasonic Plasma TH-42PZ77U Power Light Flashing 7x
Dec 31, 2007 | Televison & Video
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
