Question about Kenmore 63942 Dryer
No heat on kenmore 97272100 dryer
Unit turn on fine but does not heat. Solution?
  • 5,911 Answers
The following link explains how to troubleshoot as dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, double check your voltage at the wall receptacle. If incorrect, this will also cause the symptoms you describe. The reason: The drive motor only requires 110-120VAC to run, while the heating circuits require the full 220 service. If you are missing one leg of your 220 service, the heating circuits will not operate, but the drive motor will still run.
Next, pay particular attention to the section that discusses proper dryer ventilation. Most dryer heat related problems are attributed to poorly/imporperly installed dryer exhaust vent ducting, or a dryer that is clogged with lint preventing proper air flow. If left in a clogged condition, a dryer will actually overheat to the point of failure and you will experience repeated failures of any components you replace.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Posted on Jun 22, 2009
2 Suggested Answers
  • 1382 Answers
SOURCE: Kenmore Dryer 97272100 Dryer runs but no heat
You should have your owner's manual on hand to locate specific parts and understand how to disassemble the dryer. Also make sure that the power is disconnected from the appliance before making any repairs.
1)Check the fuses near the heating element. Inspect them for breaks inside the fuse. Replace them if necessary.
2)Test the temperature switch with a volt-ohm meter. Set the meter to RX1 and zero it out. Touch the meter probes to each terminal on the switch. The reading should be zero. Next turn the switch on and test it again. Now the reading should show infinity. If the switch fails either test replace it with a new one.
3)Check the heating coil to see if it is bad. Use the volt-ohm meter and touch the probes to each of the heating coil terminals. If it reads zero, the heating coil needs to be replaced.
Posted on Aug 29, 2009
Kenmore dryer model 97272100/ stock 72721 does not heat..replaced igniter and coils
Kenmore dryer model 72721 does not heat. Where is thermostat
Oct 08, 2010 | Kenmore Dryers
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
I own a Kenmore Dryer and it runs but will not heat. The heating coil ohms out OK and earlier I replaced the Thermostat and a switch and the unit was fine for a while. It has now stopped heating again and...
Maybe the vents are clogged in the tubing area. If so the moister sensor will not let the unit heat at all at times. Once thoroughly cleaned it should work with all the new parts installed
Apr 30, 2010 | Kenmore 62602 Electric Dryer
Aug 29, 2009 | Kenmore 63942 Dryer
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Kenmore 90 Series Model No. 11070902990 Dryer Tumbles but No Heat
Jacob, are you measuring this across the connection at the board/solenoid or to ground? It could be that there is a relay involved and you are reading open circuit voltage and then closed circuit voltages. One of the panels for your unit should have a schematic on it. If possible could you take a picture of it and post it as a photo? Have you also checked the small thermostats that are usually on the heating duct? Also check your fan squirrel cage to make sure it is still attached to the motor. Those are two common failures in gas dryers.
Sep 14, 2017 | Kenmore Dryers
Kenmore gas dryer starts to heat but does not maintain the heat. It cools down after a few minutes.
Something simple for you to try is: remove the duct from the dryer,run a cycle,IF the unit works fine, you will need to have your vent system cleaned to the outside. If you still have troubles, you will need to place a service call to have the unit diagnosed
Feb 19, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer does not dry clothes #97272100 72721
Need to replace heating coils. The little round ceramic cylinders, right in back of ignitor. Unplug
Oct 13, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
267 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
