Question about HP OfficeJet 4215 All-In-One InkJet Printer
How do I recieve faxes?
My hp 4215 will send a fax, but will not recieve them.
  • 90 Answers
Make sure you are plugged into an analog phone line (not a multiline phone). second I would put a phone on that line and have someone call it to see if it rings through. Let me know what happens
Posted on Jun 22, 2009
I can receive fax but cannot send fax on my HP 4215 xi
Check telephone out going, add std code, check FAX facility in your telephone connection
Aug 09, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I have Vonage phone line. I cannot fax to anyone on my HP 4215 officejet. My officjet is connected to the wall jack and set to "slow" settings as advised in one of the HP solution forum. that did...
Press the setup button on teh front panel and go to fax set up
Under fax setup look for
ECM - Error correction mode
By default its ON turn it off and try to send the fax
But let me thing clear the telephone line which you have has definitely some disturbence
Apr 16, 2011 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all-in-one does not send or recieve faxes. What to do ?
Try this web link ;---
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01667035&cc=us&lc=en&dlc=en
Good luck!!
Apr 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 can not send fax
Check for dial tone at the fax machine
Plug in a telephone on the cable from the wall.
Do you get a dial tone?
Yes,
Something is wrong with the fax machine.
No,
Call the phone company or a telephone repairman.
May 27, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I can send faxes, but cannot receive faxes.
Thank you for specifing your connection>
When you have a shared fax line it is import to have a Distinctive Ring Pattern which will differenciate the type of ring patter to recieve voice calls and Fax message.
All You need to do is get a distinctive ring pattern from your telephone service provider (AT&T) and setup your fax machine as per the ring pattern provided by your service provider.
All you need to do is set your rings to answer in youe phone to Rings 4 in your Phone.
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate basic fax setup> Press Ok and set the Ring Pattern to Number 5 or 6> Press Ok and cancell to come to the main menu
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate Advance Fax Setup> Locate Distinctive ring pattern and set it to the ring pattern which your Telephone service provider has alloted i.e Single Ring, Double Ring or or Triple Ring (Whichever is applicable)> Nd press Ok and cancell to come to the main menu.
Then you will be able to receive fax message voice cals and voicemail without any interuption.
Good Luck
Sep 25, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp 4215 all in one
may i know if you do have an answering machine that is connected on the line??is your line is just a regular phone line??
send me feedback for more troubleshooting instruction...
Sep 05, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
