I have a Defy Laudromaid 920 Electrologic Top loader. I have a problem with the drain/waster pump motor. The machine is off but with power switched on by the wall socket, the drain pump starts spinning and does not stop until the power is switched off by the wall socket. Can anybodiy assist? Regards, Cedric
  • 3422 Answers
SOURCE: GE Top Loader - Spin Cycle Problem
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jun 17, 2008
dtci80
  • 125 Answers
SOURCE: older GE coin operated top loader. machine fills
Prob. a simple electronic motor failure due to age, short-circuit, a chipset failure, or maybe even the filters just need to be cleaned.
For the best and safest solution you and a local mecanic should perhaps check it out.
Hope this is helpful, and greetings,
Olivier.
Posted on Oct 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: roper machine not draining
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question****
Posted on Oct 01, 2010
SOURCE: I have a Defy
my laundromaid electro logic 920 is making unususl noise when rinsing!!
tshepoflo06@yahoo.com
Posted on Apr 10, 2011
SOURCE: I have a defy electrologic
My laundromaid washing machine is not cutting water after filling please help
Posted on May 20, 2012
Defy Laundromaid Electrologic 1300 wiring diagram
Contact Defy directly and request the wiring diagram.
Feb 26, 2018 | Washing Machines
Hi, my defy laundromaid electrologic 920 washing machine had a power overload of 430 volts instead of 220 volts and now it won’t switch on. Can anyone please tell me what the problem is and what I should...
i've never worked on one of these machines but i can tell you whenever there's a power outage and then when the power comes back on the surge can take out the electronics so if you had almost double the power going into that machine i'd have to say it's fried and most likely burnt out the computer board or more.if you want to talk to someone else write back but send the full model number off of the washer and maybe someone who knows this machine can help you but the only way to tell is by checking it out with a meter and see what got damaged from the power surge but double the voltage,that's not gonna be good,hopefully there's a fuse or something in there that could be popped but check it with a meter to see.
Feb 05, 2018 | Washing Machines
Why top loader washing machine drain motor spins all the time?
the problem is in the program board still supplying power to the pump motor
Dec 15, 2017 | Washing Machines
Defy laundromaid electrologic 920 drum wont turn
Something caught between inner & outer bowl. Nail or screw caught in inner bowl. Main bearing seized, replace seal & bearing(s).
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
My defy laundromaid electrologic 1300 suddenly stops spinning and gives a ue error
I had the same problem: E9 error when switching the machine on. This indicates something is wrong with the pressure switch. (or connection to the pressure switch). When you open the top cover at the back of the machine it will be in the right hand corner (when looking from the back of the machine). This is a round device with a clear tube coming in at its bottom and a three wire connecting plug at its side. When unplugging I found one of the pins corroded (green tarnish). After cleaning it off with some steel wool the problem became intermittent - indicating the connection is not too sound. Just bending the pin slightly did the trick causing it to soundly make contact inside the plug. Problem solved!!
Aug 03, 2012 | Washing Machines
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
