Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Error code e000532-0001 for canon 4045i
What can be done to solve this, should a mechanic come?
How to fix err20 for Canon Rebel T3i?
Error code 20 refers to a detected mechanical problem
Error code 30 refers to a detected shutter problem
-Turn the power switch to < ON > to turn on the power.
-Remove and re-install the battery.
-Use a Canon lens.
-If the instructions above do not solve the problem you may need contact your nearest Canon Service Center.
Aug 03, 2014 | Canon Cameras
Canon ir600 error code E220
sira canon 600 mechan E220 has cmming turn of the power has coming solve the problam how to slove the problam slove it
Jul 17, 2012 | Canon ImageRunner IR600 Copier
My canon pixma printer is showing error code 2 140 21 while scaanning???
i got this error while trying to scan. my ink cartridges were out of the printer (i was going to get them refilled). i stuck the cartridges back in and the scanner worked again.
Jan 20, 2012 | Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
Error Code 6A00, printer not working MP830
Move you ink heads out of the way and look inside, you will see the waste ink sponges and a little white plastic flap that may be jammed in position, wiggle it a little to free it and then continue to move it to make sure its free. This should solve it for you.
Jun 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon xerox
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 03, 2009 | Canon imageRUNNER 400S Copier
Canon Pixma iP4500 error 5100
Hi You can Try
Another old posting
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Oct 17, 2008 | Canon Pixma iP4500 InkJet Printer
Getting CHECK 5100 on a Canon Fax-JX300
THIS FAX CANON JX-200 EVERYTIME CODE 5100 WILL BE COME HOW CAN SOLVE YHE PROBLEM?
Apr 27, 2008 | Canon FAX-JX200
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
23 people viewed this question
old marine
old marine
