Question about Whirlpool RBS275PD Electric Single Oven
I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still locked. Do you think it over loaded the circuit or is it supposed to go off with the door still locked? It is a 24 inch double oven and only the top oven is self cleaning. This is only about the 3rd time I've used the cleaning feature. The oven is almost 10 years old.
  • artdestin Jun 22, 2009
    Is it okay to flip the breaker back and forth on the electrical panel outside just to make sure there wasn't a power outage to the oven or an overload?
    I still think based on the time I turned it on it may still be at the end of the three hour cycle.
  • 867 Answers
Most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
Posted on Jun 22, 2009
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I used the self cleaning option and cleaned the oven now that the cleaning process is complete the oven will not heat up. the clock/timer just above the oven door works but it will not heat up at all. What...
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Dec 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Self cleaning stops aoon asfter starting.
    Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Apr 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Cannot find my book, need to remember how to start self clean process, gas whirlpool oven...thanks
    Usually a lever hidden right under the cooktop above the door that needs to be flipped to lock the door closed. then you set it to clean and let it go for hours.
    Peace,
    Feb 27, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    I have an old Whirlpool Self-Cleaning oven. I've followed the use guide instructions but still can't get the cleaning light to come on. I have both knobs to clean but the oven light comes on and the...
    Probably, in some models both the bake and broil come on to help it heat faster and hotter. In some units the self cleaning light will not come on until a certain temperature is attained. Are you setting the start time for right now, and the stop time for 2 to 3 hours from now?
    Jan 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
    you might try the following, although it is the instructions for an old model, it may be relevant;
    "The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
    A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
    I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
    Nov 18, 2009 | Ovens
    I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
    Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
     The oven must be removed from the wall to change this.
    Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    RENTING CONDO WITH SELF-CLEAN WHIRLPOOL OVEN RF376PXDQ
    If this a relatively new oven it show have a self cleaning identification on the control area or panel. Just close & select self cleaning option should take about 1 1/2 - 3 Hours
    Mar 25, 2009 | Ovens
    VDSC307-4bss how to operate self-cleaning oven
    I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
    Mar 28, 2008 | Viking VCSO244 Dual Oven
    Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
    This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
    Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
    Whirlpool RBS275PD Electric Single Oven Logo
    269 people viewed this question
    Top Whirlpool Ovens Experts
    Sal De
    Oloyede Monsuru
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
