CANON IR3045 error solve in E0024 - Office Equipment & Supplies
2 Suggested Answers
  • 64 Answers
SOURCE: copy count on ir3045
*28* copier function p msc 8
Posted on Jan 15, 2010
Having error e0024-01. All paper jamed at drum area and before delivery trey . My machine canon ir 3030. Can you help me please
Sounds like there may be a tiny piece of paper stuck in there that is causing havoc with your paper...usually at the sides. Use a flashlight, and check carefully to see if you can find it.
Dec 11, 2016 | Canon Office Equipment & Supplies
Canon iR3045 E000007-0000 how to clear the erroe
Dear
The fixing film rotates in an abnormal way.The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and, in addition, the machine fails to detect the marker signal.
check the sleeve and main drive assy.
Thanks.
Feb 02, 2015 | Canon Office Equipment & Supplies
How can i fix cod E0024-001 ON CANON IR 3225N COPIER
The developing assembly connector is disconnected
Sep 27, 2014 | Canon 3225 Copier
E00000-0001
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
May 29, 2014 | Canon ImageRunner 3045 | IR3045 |
Error code ir4570
mohon tdibantu untuk mengatasi E0024-001 untu ir4570 terima kasih
Sep 18, 2013 | Canon Office Equipment & Supplies
ERROR E0024 FOR CANNON IR2270
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
Aug 13, 2011 | Canon ImageRunner 2020i Copier
Error e000000 0007,error e000000 00024
the first error e0007 is due to fixing .u have to check fixing if ur a rep then replace the fixing film. the second e0024 is due to developer assembly .check the connector to the dev assy.try to check the toner hopper whether it is supplying the toner to developer assy.
Jun 04, 2011 | Canon imageRUNNER 4570 Copier
Canon ir4570 always jam at fuser
To properly solve the jam, you would have to start taking apart the machine, take the fuser out and inspect the paper path, a service manual would be helpful as the machines paper path in most cases is very complex, there are alot of moving parts in the path.
there is possibly a small piece of paper in the path, stuck in a gear or something similar, or a part is out of place or there is something in the path that doesn't belong there.
Aug 15, 2010 | Canon Office Equipment & Supplies
Copy count on ir3045
Jan 14, 2010 | Office Equipment & Supplies
51 people viewed this question
k24674
