Canon ir 400 paper didnot pick up the tray paper stop the pick up roller side
ctf1800
  • 4402 Answers
SOURCE: Canon D680
need to replace pickup rollers, you might want to replace all of them.
Posted on Dec 20, 2007
bambarm
  • 25 Answers
SOURCE: Paper jams constantly, without fail.
Hello, this problem may be able to be fixed. You have started out correctly by looking inside for something out of place and cleaning the rubber rollers that "grip" the paper. Next thing would be to get a higher quality of paper (heavier weight) and see if that fixes the problem. Often times a slightly heavier stock paper will work. Some of the cheapest papers are more slipery and thin. This may not be the solution you are looking for, becuase you have to use more expensive paper, but I have found that on an older inkjet printer it will allow you to print. If this does solve your problem, then you know that its a paper grip problem and you can go in and take some course sandpaper to your rubber wheels to make them grab the paper better. If this doesn't work get a flashlight and look into the paper feed when it is trying to grab the paper to make sure the intake roller is turning correctly and try to manually feed it through there by pushing the top sheet through if possible. It has to be one thing or another and you just have to go through the process of elimination to see what is going wrong with the mechanical process of grabbing the paper and getting it to go through. Most printers have a manual load area where you can feed paper through. If you have that, you can verify that the paper feed channel is unblocked. Often a tiny piece of paper is lodged somewhere that stops a new sheet from making its way through.
Posted on Oct 04, 2009
  • 39 Answers
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Posted on Dec 17, 2009
Testimonial: "how to fixing the ir 400 web roller "
  • 150 Answers
SOURCE: Paper not being picked up by roller.
Clean the one you can see above the paper tray with a cloth wetted with water or 409 or fantastic No alcohol. It should atart feeding again. Steven 805-520-3003
Posted on May 13, 2010
SOURCE: canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
I have a canon ir 1018j black and white photocopier that does not pick a paper nor photocopy
If the problem is simply that the machine is not feeding paper, you should clean the paper pick up and feed rollers. Typically there will be one attached or above the paper tray(s) and a couple that transfer the paper through the machine to the print drum and fuser. Find them and clean them with clean cloth wet with a dilute solution of dish wash detergent with a few drops of methylated spirit or isopropanol mixed in. If paer then feeds but no print - you have more serious issues.
Sep 05, 2016 | Canon IR1018J Black and White Copier
Paper jam problem
Replace the paper pick up & paper feed & paper sep. rollers in the paper tray... Good Luck
Sep 01, 2012 | Canon iR 2016i Black and White Copier
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
How to remove canon ir 400 paper feeder assembly
Why???? The unit comes out the right side of the copier. There are alot of screw to be removed. You can take the paper trays out and remove a paper jam and also replace the rollers. If the paper tray is not lifting? There is a lift gear that breaks and it is not easy to replace> I have over 20 years and it is not easy to do......
Jul 28, 2010 | Canon imageRUNNER 400S Copier
Canon ir 2016 is asking paper size, while paper in tray are correct. what is the problem
It could be several errors.
1) do you have paper size senzor on paper tray set according the paper in?
2) It coud be that you have problem with paper pick up clutch
3) check the registration sensor flappers, door on the left of the tray flapper,...
4) try to clean the rollers
5) compare your paper lenght with some other paper manufactors
May 17, 2010 | Canon imageRUNNER 1023iF Black and White...
Canon ir-400 error load paper when i give data print
More than likely your computer's setup for where it is to pull the paper from has designated the manual bypass tray (the flap on the side of the right side of the copier that holds paper) as it's main source. Go into the control panel/printersandfaxes/ and look under the profile tab of your copier. Good luck
Dec 09, 2009 | Canon Office Equipment & Supplies
Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Nov 12, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 2016 digital copier
Are you living in the USA? The size A4 is the Europe size of paper to our letter size... You can try to take the paper tray out and look inside, for any paper jammed in the back of the paper tray area.
Mar 19, 2009 | Canon Office Equipment & Supplies
I have a canon image class d680. the machine no
Have you tried to clean the pick up rollers with a rag with a small amout of WD-40 or Simple Green. Clean the roller then whip off with a dry rag. If the problem improves you need to replace the pick up rollers. If not you may have to replace the paper feed clutch. Also, look to see if the seperation pad is ingaging when the paper tray is pushed in. Open the left side door. I've seen the actuator break. Also, have you tried to use the manual feed tray???? I know you made sure the paper guides in the paper tray are set correctly for the size paper in the tray??? Good Luck
Feb 26, 2009 | Canon Office Equipment & Supplies
44 people viewed this question
jasbo
jasbo
