Pleas. Help i ned. Riso ez 220 u. The roller is not play. Jam paper. In the center. The roller. Do not up. What is a problem
2 Suggested Answers
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
Posted on Jun 20, 2009
Risograph pressure roller isnt coming up
Dust on paper exit sensor? (small hole between the exit belts)Sensor blocked or defective?
Sep 12, 2012 | Riso Office Equipment & Supplies
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
We have a gr 3750 and when the paper tray comes up the feed wheels do not start up to feed the paper in.Any suggestions
  1. check the upward sensor for adjustments and the sensor on the stripper pad unit for adjustments
Mar 13, 2011 | Riso Office Equipment & Supplies
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Paper feeding problems Riso TR1510
refix your ink cartrdige also check there is not any paepr jam issue.
also some times printer neeed servicing creates this type of issue.
Mar 28, 2009 | Riso Office Equipment & Supplies
first try paper feed clutch.. make sure nothing is blocking paper path...
Feb 03, 2009 | Riso RZ220 Duplicator
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Riso Rz 220 copies are coming out to light.
1)You can set the dencity of the riso on the controll panel before you do your masters.
2)Always use original ink.
3)If you are a bit technical you can remove the pressure roller and strip all old ink buildup from it.was it with water ann soap.
If you open the drum and take it out completely,the pressure roller is the black roller inside the machine that put directly pressure on the drum.There is only one screw to loosen and then it hooked out,but it can be tricky to hook it back if you not doing it every day.
Oct 29, 2008 | Riso RZ220 Duplicator
54 people viewed this question
k24674
jasbo
jasbo
