Question about Refrigerators
Whirlpool art 856g
No work refrigerator
My refrigerator does not work
if it is an older or out of date model get a new one
Jan 28, 2013 | Whirlpool Refrigerators
I have a Whirlpool fridge freezer ART 731. The freezer is working fine but the fridge has started to get too cold and freeze the items inside although the control is at its lowest.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Whirlpool ED5FHEXMQ Side by Side...
WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Jul 30, 2010 | Whirlpool Refrigerators
My whirlpool ART 900G fridge freeser, the freezer works but the fridge wont chill
Check the fan that moves the air from the freezer side to the refrigerator side. It is either stuck in ice or not working. Defrost the refrigerator for 24 hours and then restart it Listen for the fan operation be aware that the fan may shut off when you open the door, so listen closely. Defrosting it may fix or the fan may need to be replaced.
Nov 12, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Why doesn't ice and water dispense? ice still makes and collects in bin but nothing dispenses.
This is a simple repair and you can save a lot of money by repairing it yourself. Your switch has gone out and if you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number, we will get the correct [art out to you right away!
We look forward to working with you!
Thanks, Ella
Nov 09, 2009 | Whirlpool GS6NBEXR Side by Side...
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
