Question about Birds
Native birds of the south burnett
Grey bird with a lemon coloured crest N\ nanango area
Kawika-56
  • 233 Answers
SOURCE: Bird animation
Right click on it, and select "Save Picture As..."
Leave the file name as is, or change it to anything you want.
Posted on Nov 05, 2007
mick-40
  • 94 Answers
SOURCE: Bird Rear-end Size
Hi meduck4,heres what you need brother as I cant see your diff, 3 ways to tell what you have:
#1 The first is the driver's door tag; there will be a one-letter or one-numeral axle code listed there. You can then compare it to the chart below: CODE Rear Axle Ratio Conventional Locking 8 M 2.73 Y Z 3.08 F R 3.45 5 E 3.27 6 W 3.73
#2 The second is the axle tag, attached to the lower lefthand bolt on the rear axle itself. The bottom left line will give you the gear ratio, and the type of rear end (S for limited slip non-locking, and L for locking).
#3 The 7.5" rear axle height is shorter than the width and the shape appears "oval".
The 8.8" rear axle
dimensions are equal and the shape appears "round".
This will tell you what you have my friend,good luck
Posted on Nov 13, 2008
JonnieC
  • 139 Answers
SOURCE: Bird safe
rub on it with your stylus and then blow into the mic
JonnieC
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: I am getting a squeaking noise that almost sounds
Are you sure it's from the right rear area? I had something similar happen, and it turned out to be the bearing that joins the front and rear drive shafts at midship. Replaced the bearing, and the noise is gone.
Posted on Dec 24, 2010
  • 17 Answers
SOURCE: What's your problem?Our bird cage finish is chipping. Can I paint it myself?
My recommendation is to call the manufacturer for paint recommendations and, believe it or not, some cage manufacturers will do that for you. In any event, you must make sure the paint is nontoxic since most birds do scratch it with their beak. After painting Make sure you let it dry completely: Permit the paint to dry for at least 48 hours before moving your bird into the cage, so be prepared to have a secondary cage on hand. Also you should know that although paint may be nontoxic when dry, there are paints may be harmful to your bird if inhaled, so paint it as far as you can from your birds, outdoor area preferred.
Posted on May 14, 2012
Best bird houses
we use to run an aviary raising birds
#1.just make sure to locate the opening facing south
#2 make sure to have a landing perch below the entrance
#3 make the nest box the right size. small song birds and finches
like a narrow and tall box 6"x6" x15" with a 1 1/4" hole
Oct 28, 2017 | Birds
How to get rid of lice on small birds
No idea of your country but a 20Second google search revealed this;
To remove lice, it is recommended to use a mild pet insecticide, such as "Nuvan." After spraying the plumage, wait for 2 - 3 minutes and then gently ruffle the feathers over a white tray or plastic sheet to collect the lice which fall from the feathers.
I found that one great way to remove lice and mites from your birds is to sprinkle Sevin Garden dust under their wings and tail, and on the back. Check the birds the next day and if there are still lice present, repeat the process, as needed. I found Sevin dust [active ingredient: Carbaryl (1-napthyl N-methylcarbamate)] equally effective in getting rid of red mites.
Avian Insect Liquidator is another way to get rid of mites, lice and other insects in the birds' environment. This all-purpose insecticide from Vetafarm contains a water-based insecticide that is harmless to birds but effective against insects.
Prevention:
Sanitize and treat the birds' environment (cages, perches, aviaries, nesting areas, etc.). Secondly, allow your birds to bathe daily. Most birds enjoy doing so and if you provide them with a shallow clean dish, they will usually be happy to bathe without encouragement. Some birds like to be misted, or even sprayed. Sprinkling Sevin dust underneath nest bowls and around nests will eliminate all kinds of insects.
Aug 06, 2017 | Birds
I am trying to find out what kind of birds are coming to my feeder ,so I can buy the corrtect food for them.
lots of books world wide
on" local area bird identification "with pictures
librarys ,google images ,
"whats that bird " for example
RSPB What that Bird
Sep 20, 2016 | Whitehall Products Verdigris Hummingbird...
Identify birds in indiana
Could be a tufted titmouse?
Jun 29, 2014 | Pets - Others
Bird identification pictures
Robin size bird of soft grey with almost red beak.
Jan 01, 2014 | Computers & Internet
Where in my home should I not hang my bird cage?
You should avoid hanging your bird cage in any of the following areas:
In an area where there are drafts
In the kitchen
Anywhere where direct sunlight will shine on the cage
In front of an air conditioning unit/heating vent
Bird cage placement is an extremely important part of your birds life and health. I have found a great video on bird cage placement within a home. I suggest checking it out.
http://www.howcast.com/videos/217395-How-to-Choose-the-Best-Location-for-Your-Birdcage
Aug 30, 2012 | Absorption Corp Birds
What is a play-top bird cage?
A play-top bird cage is ideal for active birds. They are designed with a play area that sits on top of the cage's surface. Some models are designed with a detachable play top that allows you to remove it and take to any room of your house. Here is an example of a play-top bird cage -
Aug 29, 2012 | Birds
May 14, 2012 | Birds
Birds Logo
65 people viewed this question
Top Birds Experts
DaveMc3
DaveMc3
Heartland Ho
Level 1 Expert
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
