Question about Steinberg Cubase SX3
I can hear sound through midi only
I can only hear sound coming through my speaker when I'm playing midi, I can only hear audio sound coming through my headphones when I put my connections on SPDIF, whats wrong? I've tried everything, I have two layla echo events hooked up to my Cubase, but I just can't get audio sound coming through the speakers.
Try checking in your device manager. If you have computer speakers and a soundcard...disable the speakers so they will go thru the soundcard...i just had the same problem...but now I have sound but can't pcik up the mic!! AAHHH!
Posted on May 05, 2009
  • 4 Answers
Ok my friend i will try with you
just try to install the software of card sound correctly if you dont have drivers just go 2 this web site and contact me 2 tell you how 2 install the driver
Posted on Dec 24, 2007
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I am only hearing audio out of my left headphone speaker when plugged into the Tascam US-122. how can I play back my tracks and have the audio fill both speakers?
you might be using a mono output jack or input jack.....check the jack end...1 ring = mono / 2 rings = stereo
make sure your sending a stereo signal in, then check the L/R balance.
Jul 06, 2011 | Tascam US122 Audio/MIDI Interface with...
I have a SoundMAX Integrated Digital Audio soundcard in my Windows XP pc and in the Midi Music Syntesizer, I have the following Syenthesizer default sets in the control panel: SoundMAXGeneral MIDI and...
Ok right click on the speaker icon next to the clock and press adjust audio properties, a new window will open up with about 5 tabs on top, click on the audio tab and click volumn under sound recording and another window should open with mic, line in, stereo mix/what you hear etc now if you see stereo mix or what you hear put a check mark in the box so you can play music via the web.
But if you don't see it click on options then click properties and list of name's should appear scroll down and find stereo mix or what you hear and check the box and it should now appear next to the mic.
Hope this helps.
Jul 03, 2011 | Computers & Internet
I cannot hear any microphone playback
I cannot hear any microphone playback 2) Installing the driver software for it takes sound out of my computer my microphone seems to be fine because the green light comes on when i test it, but no playback in speaker when i record. I know im jus missing one little thing...can you help me?
Feb 08, 2010 | Tascam US-122 USB Audio/MIDI Interface...
Yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Jul 18, 2009 | Music
My speakers work but I cannot hear anything on my computer except when I play a cd. What could be wrong?
go to the audio settings in control panel and click on the advance button, go to properties and check the neccessary sound mix you require like Midi, wave, video and auxillary. make sure they are not mute and you should be fine
Jul 17, 2009 | Computers & Internet
My MIDI won't play back even when I play the file, no matter which program I use to play it. The computer I use is a Compaq Presario, I have Cakewalk Home Studio 2002 on it, and my sound card is SB X-FI...
The default MIDI setting of your PC may have been set for another MIDI device (for example, if Cakewalk Home Studio has been used with a MIDI compatible keyboard). Go to... Control Panel / Sounds and Audio Devices / Audio / MIDI music playback and change the setting back to your soundcard (and set as default if you prefer).
May 03, 2009 | Computers & Internet
Tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Feb 01, 2009 | Tascam US-144 Sound Card
Sound problem
if ur usung win xp OS U shold restore OS (pgm-accessories-system tool.restore )to back date while it in workinfg fine
Jul 19, 2008 | Edirol UA-4FX External Sound System
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Open Questions:
See all Steinberg Cubase SX3 Questions
Computers & Internet Logo
127 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Donald Currie III
Level 1 Expert
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
