Question about DeLonghi Heating & Cooling
Delonghi heaters can you lay them flat for transport?
Will be moving so need to know if we can lay the heater down or keep it upright? Thank you
SOURCE: Presto HeatDish
I had to go and bypass the buzzer.
Posted on Dec 08, 2007
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Posted on Dec 15, 2008
  • 24 Answers
SOURCE: removing seats from 2002 yukon xl
I found a Owner's manual online...I can email it to you. I have it in an Adobe file.
Jason
jbro1973@yahoo.com
Posted on Jan 12, 2009
  • 11 Answers
SOURCE: Need replacement caster for DeLonghi
Available from De Longhi site or Fox International.
Posted on Jan 30, 2009
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
My heater was on and fall down for 1 hour an d now its not working
Unplug, set upright, let oil go back down to base. Check owners manual for reset. Make sure to let unit set upright for a couple hours then plug in and try operation. If unit still does not work contact Delonghi and maybe they can help.
Apr 19, 2014 | DeLonghi KH190715 Oil Filled Radiator...
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Moved unit, wont get cold
did you transport it upright or laying down.... depending on who you talk to you will get a different answer... i have been in the appliance business for 18 years and have to say the more i hear they are transported laying down the more i hear troubles... either way after transported or moved they should be left sitting for approx. 24 hours to allow all the oil to settle back down,,,also could have developed a leak in the sealed system one of the refrigerant lines leaking.
Feb 14, 2011 | GE Refrigerators
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
I have a toshiba 65H82 tv i need to move to my new house. can i lay it down or does it have to be upright?
Move it upright best for the tv.These tvs have chemicals in it three CRT tubes colors guns.
Sep 08, 2010 | Toshiba 65H82 65" Rear Projection...
I wish to move my Panasonic Vieta to another address.
I would wrap a thick cloth towel, blanket or comforter around the screen and lay it face down (screen down) on a flat surface, making sure the TV will non move in any way. If you transport it face up, there may be a chance that something may fall on the screen and damage it.
Jul 17, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Need to transport older Kenmore upright freeer
I would not lay it down but if you can get around it lay it down so the compressor is at the bottom. DO NOT TURN ON FOR 24 HOURS AFTER STANDING UP.
Apr 17, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I need to know if it is possible to transport side by side refrigerators laying flat. or almost flat. This will be a short move for about 1/2 hour.
Hello, Yes you can move your side by side laying on it's back..it is most important though that when you have it in it's new place you leave it unpluged for 24 hours so the oils can run back into the compressor. If you have any other questions please feel free to comment again...Mike
Aug 24, 2009 | Refrigerators
I have a 50 inch big screen hdtv and i am moving i want to know can i lay my tv down flat?
Yes you can lay it down flat on its screen just make sure it is padded so the screen doesnt get scratched. I transport projection units this way all the time even DLPs however do not transport LCD or plasma units in this manner as thats not recomended.
Mar 30, 2008 | Televison & Video
Heating & Cooling Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
