Question about Braun Kitchen Appliances - Others
Where can I find the water filter for Braun WK 210?
The filter for my kettle is torn apart so I need a new one.
2 Suggested Answers
SOURCE: My Braun electric kettle won't click on. Do I
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Posted on Mar 02, 2011
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
Feb 05, 2016 | Kitchen Appliances - Others
My kettle light is off and cannot heat
It has died Stephen! Get a new one - it will be cheaper than fixing this.
Jan 09, 2014 | Braun WK200 Electronic Water Kettle...
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
My tea kettle leaks from the bottom
I just took ours apart for the same reason. In our case, it turns out that one of the two water indicators was cracked (at the top), causing the leak. The cracks were invisible without taking it apart.
There's a bigger leak near the bottom of the same piece, where a piece of the plastic is missing:
On the upside, the wk600 is really well designed - easy to take apart for repair. But I can't find replacement parts anywhere...
Feb 25, 2011 | Braun WK600 Cordless Electric Kettle
Shuts off
Does the unit shut off only before the water boils, or does it shut off and on periodically? I just fixed my friend's WK200 Braun kettle. His would shut off and on, eventually coming to a boil. During normal operation, when you press the switch, it is connected to a rod which at its other end (ie the bottom of the kettle) is able to close the circuit allowing the current to pass through the heating element. In my friend's case, the contact had become weak - I just had to slightly bend the metal pole a little bit to provide a better contact when the switch was depressed. To repair the unit, I only needed a couple of torx screwdrivers and a voltmeter to measure continuity. (note, if you bend the metal pole too much, then the circuit will always be closed even when the switch is OFF - make sure you test for an open circuit when the switch is OFF)
Jan 29, 2010 | Braun WK200 Cordless Electric Kettle
HOW DO YOU REMOVE ALL OF THE BROWN RESIDUE FROM A BRAUN WK200 KETTLE?
There are comercial products that will do this look for it in houseware stores, maybe some big Ace Hardware stores, maybe even at your chain grocery stores.
Feb 26, 2009 | Braun WK200 Electronic Water Kettle...
Kettle shuts off before boiling?
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
Aug 29, 2007 | Braun WK600 Cordless Electric Kettle
Kitchen Appliances - Others Logo
62 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
