Question about ION Audio iED01 Electronic Drum Set
Software for VR Drum - ION Audio iED01 Electronic Drum Set
Vr sportfishing serial
Please purchase the software to get the serial numbers. If you have already purchased the software and have lost you serial numbers, please contact VR support.
May 30, 2012 | Pishtech VR Sportfishing
Gray copies geting worse and worse
You make my smile... I was factory trained on that model. Have you had the optic's ceaned resently? If so, did the clean the fold back mirror or the sixth mirror & the dust proof glass? That should take care of most of your problem. Also, there is a a lamp adjustment "VR" behind the rear top cover. I would clean the optic's before adjusting the "VR" Good Luck
Feb 22, 2010 | Office Equipment & Supplies
Ion ied05
check out comment #2 in
http://www.wibwobweb.com/blog/articles-by-me/using-the-ion-ied05-usb-drum-kit-with-midi-capable-software/
that is a workaround that worked for me
Aug 30, 2009 | ION Audio iED01 Electronic Drum Set
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Asking questions about cannon np7161
at the back of the machine check for vr 1 and adjust slowly and print
Oct 19, 2008 | Office Equipment & Supplies
Audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
Jan 20, 2008 | Radio Communications
ION Audio iED01 Electronic Drum Set Logo
Top ION Audio Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an ION Audio Toy Expert? Answer questions, earn points and help others
