Question about ASUS Computers & Internet
Fixing faulty spacebar - ASUS Computers & Internet
  • 31 Answers
Can you define what you mean by faulty Norman. If the plastic that holds the spacebar in place is broken. A picture says a thousand words if you'd like to upload it to show us what you're trying to describe, that would be fantastic!
Posted on May 09, 2014
2 Suggested Answers
  • 309 Answers
SOURCE: dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Posted on Jan 05, 2010
The spacebar on my Sony laptop is not leaving spaces be tween words when e-mailing.Hw can I fix his as i's verynnoying
The space-bar can be lifted off using a small screw driver , this will reveal whats underneath , as it clips onto a wire structure that acts like a spring as well as pushing on the electronic button to send the signal , this can be faulty due to dirt getting lodged under the space-bar or a misalignment problem with the mechanism its self and can usually be fixed once the plastic space-bar is removed , but take note when removing the plastic space-bar key in regards to how it is attached and the position of the wire spring system so that after fixing replacement is easy .
Jul 06, 2014 | Sony Computers & Internet
My spacebar is not working how can i fix this
If on a Desktop, it's best to buy a new keyboard. On a laptop, where the kb is fastened to the case, try blowing out from under the spacebar with compressed air. That kb can be replaced too, but it's a hassle.
Mar 18, 2014 | Computers & Internet
Fix spacebar
On a Desktop, just purchase a new kb for $16 or so. On a laptop, it's an involved process to replace the kb.
To get a space without a spacebar, try these two suggestions:
- Press Alt/32 (that's Alt with 3 2) then release the Alt key.
- Run OSK and click the spacebar.
The actual model number MIGHT get you a repair procedure in a Google or Youtube search for "repair spacebar".
Oct 28, 2013 | Computers & Internet
(Remington Streamliner) the space bar automatically tabs instead of moving one space forward. How do I fix this?
This can mean that the spacebar is not being tapped hard enough, the spacebar is sticky, the escapement is sticky, or the spacebar linkage needs adjusted. If the letters do not cause this, then the escapement being sticky is less of a concern. Sometimes the touch on the spacebar is right on the point where the escapement mechanism just barely escapes and doesn't lock in. First try tapping the spacebar more firmly to see if this helps.
Aug 14, 2013 | Office Equipment & Supplies
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
When i press spacebar my search results page appears
Keyboard replacement solved the problem. In my case it was a faulty Logitech keyboard. It seems that Spacebar is acting as F3 and Space the same time.
Feb 04, 2010 | Logitech 967437-0403 Keyboard
Dell inspiron 6400 faulty spacebar?
Jan 05, 2010 | Dell Inspiron 6400 Notebook
Keyboard Failure
Buy a new one.not worth fixing.RICHARDM69
Aug 31, 2009 | E-Machines AAFQ50400000K0 Keyboard
Spacebar/will/not/space
just take it it up the spacebar key with a pen or anything like a pen and clean inside of the keyboard which is the spacebar is placed and fix the spacebar again and type
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
