Question about Dyson DC26 Bagless Canister Cyclonic Vacuum
Why Dyson DC26 brush works intermittently. Most of the time the brush will not spin.
SUPERMAN_B_1
  • 294 Answers
SOURCE: the brush on my Dyson DC-14 wont spin
hello, have you checked to make sure you have nothing wraped around the brushes ? also it sounds like your belt needs to be replaced.
Posted on Mar 31, 2009
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
SOURCE: Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Posted on Sep 08, 2010
DysonInfo
  • 107 Answers
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Posted on Dec 20, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson DC24 brush no spinning.
    Hi, it's Jack from Dyson.
    You may find it useful to try pressing the button in as far as it will go - this should resolve this issue for you.
    However, if you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), and we can run through some checks with you over the phone.
    Kind regards,
    Jack
    Posted on Jun 07, 2011
    Dyson brush roller spins intermittently. it starts out good but then stops
    Do you have a burning rubber smell at the same time? Turn the machine over and remove the bottom cover. Hook a loop of cord under the belt, pull it up wards and pull the brush out. Remove one end cap and pull the spindle out from the other end. Remove the fluff and hair that is tied around each end.
    This shows quite well.
    https://www.youtube.com/watch?feature=player_embedded&v=cYqOEpZgocg
    Put the brush back and see if that fixes it. If not, then you need to change the two belts, and possibly the clutch. The same guy at Vacuum spot shows clutch servicing, but you may wish to get a professional to do it. How to check the Dyson DC04 Roller Brush Bearings
    Mar 21, 2016 | Dyson Vacuums
    Tip
    Dyson DC26 - Washing the filters
    To wash the pre and post-motor filters in your Dyson DC26, please follow the simple steps shown in the video below. This procedure applies to all Dyson DC26 variants.<br /><br />The filters should be washed every month using cold water. Always ensure the filters are totally dry before refitting them - this may take up to 24 hours.<br /><br />For further help and advice please visit <a href="http://www.dyson.com/">www.dyson.com</a> and click on Support. <br /><br />Dyson Customer Service<br /><br /><utube src="m4C27jcFSzU&feature=related"><br />
    on Jun 22, 2011 | Dyson DC26 Bagless Canister Cyclonic...
    Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
    I can think of three things that could be wrong.
    The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
    The internal drive belt is worn, or the nylon bush that it runs on.
    The clutch is worn out.
    The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    How do I disassemble a Dyson DC26 Carbon Fibre Turbine Head (920545-02)?
    Hi Kristian, it's Jack at Dyson.
    It's very unlikely that an internal component would have broken after the blockage was removed. Instead, it's worth checking that the plunger is in the correct position. If it's pushed inwards, this will shut off the brush bar, so make sure it's pulled out:
    If the plunger won't stay in the out position when you switch on your vacuum, this indicates there may still be a blockage within the Turbine head which needs to be cleared.
    This should resolve the issue, but if you find it doesn't help, please get in touch so our experts can provide further assistance. Please be aware that dismantling the Turbine head any further than is shown in the User guide can void your Dyson warranty, meaning future replacement parts or repairs could be chargeable.
    You can reach our experts by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Jul 05, 2015 | Dyson DC26 City Multi Floor Bagless...
    My dyson DC26 power button has to be held down to work
    Hi there, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty with your DC26's on/off button. You should not have to continually hold this down for the machine to work, so it sounds as if your vacuum may need a repair. If you can get in touch with our experts directly we'd be happy to discuss your option, and we can also confirm whether or not a repair would be covered under your Dyson guarantee.
    When you have your DC26 to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    We'll look forward to speaking with you.
    Jun 22, 2015 | Dyson DC26 Bagless Canister Cyclonic...
    Carpet brush does not work on dc26
    With this model, the most likely cause is that the brush has become clogged and won't spin freely. Unplug the unit and test spinning the brush bar by hand. If you really can't get spin, follow instructions like these (
    Dyson DC26 DC35 DC36 DC38 DC44 DC45 DC47 Clearing the brush bar Official... that are straight from Dyson). Make sure you get the very ends fiber-free. It should spin better now.
    Good Luck!
    Jul 07, 2014 | Dyson Vacuums
    Why is my dyson26 is scratching my wooden floors when brush is turned off?
    The heads are designed to be used with the brush on hard floors. On the bottom of the brush head there are either Metal or plastic pads. If you use this on a tiled or hard floor without the brushes, these can wear and become sharp in places.. This scratches the floor!!
    Apr 27, 2014 | Dyson DC26 Bagless Canister Cyclonic...
    Why wont my Dyson DC26 Beater brush stay on?
    The popper is not in the right position!
    Apr 26, 2014 | Vacuums
    Dyson dc 24 brush works intermittently
    Broken wires in the side of the machine
    Dec 27, 2013 | Dyson Vacuums
    Hi Chris, it's Jack at Dyson.
    DC24's brush bar is designed to shut itself off for protection if something jams it. Please follow the steps shown in the video attached to remove any threads or hair from the brush bar and end cap, and to check the cleaner head for any obstructions. Once you've done this you should be able to reset the machine.
    If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a repair or a replacement part is needed, we'll be happy to confirm if this is covered under your machine's 5-year warranty.
    You can also find help and support by visiting www.dyson.com and clicking 'Support'.
    Dyson DC26 Bagless Canister Cyclonic Vacuum Logo
    73 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
