Question about Sun STOREDGE DAT 72 DAT Tape Drive
How to find out dat 72 serial no - Sun STOREDGE DAT 72 DAT Tape Drive
Can i get a SCSI Cable for Sun StorEdge DAT 72
You shouldn't have too much trouble, they are a bit old hat but you should be able to get one from most PC shops/repair shops, some electrical retailers but I'd try ebay for the cheapest option.
Here's a male to male version on ebay:-
http://www.ebay.co.uk/itm/External-HD68-HD68-SCSI-Cable-60cm-/250734116201?pt=UK_Computing_CablesConnectors_RL&hash=item3a60eafd69
Just ensure what terminals you need at each end of the cable, there are various choices.
Sep 01, 2011 | Sun STOREDGE DAT 72 DAT Tape Drive
I getting clean light on HP dat drive? please help .
You need to load a Cleaning Tape into the drive. Tape drives have special tapes just for cleaning.
Jan 04, 2011 | HP StorageWorks DAT 72 Tape Drive
Anytime I try to backup or copy a 33GB data file on a 40GB or 72GB Data cartridge, it requests for more data cartridge even after formatting the data cartridge prior to starting the process. Sometimes, the...
Because the DAT72 can copy 72GB with 2:1 compressed, and it's native capability is 36GB in the most. So you can try to copy less than 30GB data to it or try to enable the drive's compress mode.
Nov 26, 2010 | HP StorageWorks DAT 72 Tape Drive
Quantum tabltop usb drivers for XP SP3 latest version
1. Go to: http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/DAT72Drives/Index.aspx#Drivers
2. Click on the "Download Now" button opposite to "DAT 72 Drive Driver for Windows XP".
3. Proceed with the download instructions.
Dec 03, 2009 | Quantum DAT 72 USB TABLETOP (CD72SE-SST)...
Certance DAT 72 tape drive stopped communicating with PC
We have had the same problems with HP drives and Veritas. In our case it was not the drive per se. While I am assuming that based on the date of your post that you have moved to another solution, however, I will provide for you what we did.
First shut all down, disconnect the tape drive from the scsi cable, then restart. Go into computer management and turn all your backup exec services from auto to manual. Now go to devices and do a rescan. Once this is done and you see no tape drive whatsoever in the devices shut down the server. Reconnect the scsi cable to the drive and restart.
Go back into computer management, back to devices and rescan for hardware changes. Do you see it? If so, good! Sometimes a re-seating of connectors will do that. On the other hand, it could also be a tape driver from Veritas that just doesn't work (my case), take the original driver cd that came with the unit and start that loading up. Can you see it now? Can you use windows backup to access the tape drive? Now go into services and start the services individually. Go into backup exec and see if you can read your tape. Go back to services and reset all services back to auto. If you ever have to reinstall/upgrade backup exec, think twice about using their drivers.
Nov 12, 2009 | Certance Internal DAT 72 (cd72lwh-s) DAT...
Garmin 72 to laptop serial to usb
One of These will work for you, no programme needed.
Here
Regards
Jan 16, 2009 | Garmin GPS 72 GPS Receiver
Dell Dat 72
try a different Cleaner tape, they dont last forever..
Jul 24, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
DAT 72
here select your OS and then the latest firmware
Mar 02, 2008 | HP StorageWorks DAT 72i DAT Tape Drive
Sun STOREDGE DAT 72 DAT Tape Drive Logo
55 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
