Question about Maytag 24" Tall Tub Portable Dishwasher - Black
Dishwasher does not drain
I have a Maytag Jetclean Super Capacity Quiet Plus II, model WDB6000AWA. It has stopped draining and I can't find the drain. I tried to go to the website to download the owners manual and it won't download. I just need to know 1) where the drain is and 2) how to clean it out, if needed. Thank you!
    Problem Solver:
  • 5 Answers
The drain runs from the dishwasher into either the side of your garbage disposal, or directly into your sink drain. If it is running to your disposal, pull the hose and make sure that the plug in the disposal (where the hose connects) is knocked out. Some have been known to install them without removing the plug. Either way, pull the hose loose and you can use a compressor to blow through it. If the air comes back through the dishwasher, then you are probably blocked in the main drain.
Posted on Jun 22, 2009
My Maytag dishwasher model number mdb8600AWS is not draining. HELP
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 22, 2010 | Maytag 24 in. MDB8600AWS Jetclean II...
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Dishwasher
if you installed a new garbadge disposal at the same time have you popped the factory drain plug on the disposal where the dishwasher drain tube connects to the disposal. The plug is inside the disposal dishwasher connection tube . You cant see it . Just drive a screw driver through it with a hammer.Itt will pop out and then the dishwasher will drain.Just a thought.I forgot to do this to mine.
Mar 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24" Tall Tub Portable Dishwasher - Black Logo
362 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
