Question about LG WM2487H Front Load Washer
Whirlpool wf665/1 soap dispenser removal - LG WM2487H Front Load Washer
How do I fix a whirlpool model number WFW9050XW00 soap dispenser overflowing water and not going into the tub?
Whirlpool WFW9050XW01 Use Care Manual Page 12
Sounds like the line between the soap dispenser and the tub is clogged. If you look at page 12 of the link I provided, it will show you how to remove the dispenser tray. Check, with a flash light and see if there is any obstruction. You can use a small flexible plastic snake to clear any obstruction.
Good luck.
Semper Fi,
Z
Aug 03, 2017 | Whirlpool Washing Machines
My soap dispenser does not clean out. ie fabric softener compartment does not rinse all of the fabric solution out.
Hi, remove the dispenser draw and clean out, you'll probably find a load of unused soap and softener gunked up in it
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking out the soap dispenser.
Remove the soap dispenser and clean it throughly, next check the tube from dispenser to the tub to be sure it is clear of blockage. Run the washer with hot water to clear any residual buildup that may be left in it.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dishwasher DU840SWP. soap dispenser not opening during cycle
Does the washer heat the water during the hot cycle. If it does, your soap dispenser module in the door is faulty. To install, you need to pull power plug out first,then sit on a chair in front of the door and then open the door towards yourself. Once open unscrew those screws along the perimeter of the door to enable you to remove outer panel. Once off, you can view how to remove soap dispenser. If water does not get hot, check the heater element and/or the reset (over temperature switch). Note, top rotator must move freely as well to allow hot water dispersion which on some occasions activates the soap dish. On other occasions it uses a solenoid switch.
Oct 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Duet whirlpool leaking water thru soap dispenser when off.
remove dispenser and clean next ck tube from dispenser to tub be sure it is clear
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking from door
Gasket around soap dispenser is not sealing. Remove dispenser check gasket. Also inspect dispenser for cracks.
Jul 24, 2008 | Whirlpool Dishwashers
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Dispenser door
Remove the outer door panel and check the actuator for the soap dispenser door it is probably broken. You might also check and make sure you don't have an old soap build up inside the soap dispenser. Sometimes old soap builds up and dries inside the dispenser and causes the door to stick. It should be free. Good luck.
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
LG WM2487H Front Load Washer Logo
26 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
