Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
SMSUNG SATA HDD NOT BEING DETECTED
HOW TO FIX THE PROBLEM
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
Mar 27, 2009 | ASUS M2N-MX Motherboard
My hdd sata is not detected by motherboar.
brohter you should chek you r hardisk and then check ram GOD WILLING YOUR PROBLEM WILL BE RIGHT IM RIAZ AHMED BROHI FROM PAKISTAN PLEASE EMAIL riazbrohi@gmail.com
Jan 24, 2009 | MSI K8MM-V Motherboard
My brand new ASUS ee PC notebook won't boot up. Any suggestions?
check in the bios settings if the hdd is detected..if detected,you need to re-install the windows..if not detecting,you must replace the hdd...ahh! i think the hdd for this laptop is expensive..coz i know its something special..not same like normal hdd in laptop,like ide or sata..its small hdd inside the board...half size for the 2.5" hdd sata or ide
Nov 23, 2008 | ASUS Eee PC 900 16G Notebook
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
55 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
