Question about Garden
Replaced coil, checked on-off switch but still no spark to plug
  • Anonymous Mar 27, 2014
    I check spark & did not have spark at the plug wire Then I disconected stop switch to see if it had a problem still no spark. The wire is in good shape Is it a bad coil or could it be somthing else?
  • 59 Answers
Check plug turn coil over
Posted on Jun 23, 2009
Engine stop
If theres no spark from the spark plugs then you would have to replace them?
Jul 12, 2008 | 1993 Toyota Corolla
Ut10942d. I have replaced the coil,flywheel,plug,o/o switch. cannot get a spark
Check the wires going to the switch be sure they are not grounding out somewhere. Also check the spark plug wire. The clip that connects to the spark plug may not be making contact with the spark plug wire.
Sep 28, 2016 | Garden
Fully charged battery on my 1996 cb500,choke out however wont fire up just does a little puff like sound
NO - SPARK
Check for spark at spark plug.
1. If no spark, test the wire to the coil with test light and see if you have power to coil.
2.If no power to coil, make sure your on/off button is on and working.Use test light.
A. Power at the switch but not at the coil indicates a broke wire from switch to coil.
B. NO power at the switch indicates ingintion switch is off or faulty and not sending power to your switch , make sure key is on. Use trest light.
3. If you have power to the coil but no spark from the coil - replace the coil
SPARK
Check for spark at the plug
1.If you have spark at the plug, but not starting - check that your carbs are getting gas.
2.Petcock Could be off, Fuel Filter could be clogged, Carbs could be dirty or clogged and your not getting any gas.
3.Pull spark plug - If no gas present then your not getting gas, if wet then you getting gas and your flooded. Make sure you have good gasoline, Bad gas won't burn.
or your bike is worn out and dont have any compression.
With Good gas, and Good Spark, and Good compresssion, the bike will run.
If your not getting gas to your motor through the carbs, pull carb off and thouroughly clean it.
Dec 03, 2010 | 1997 Honda CB 500 S
No spark
There's no emergence switch, if there was it would only be for fuel and not spark, there four thing to get spark,
ignition control module, ignition coil, distributor pick up assembly and spark plug wire's check for spark at coil, more then likely it's going to be your distributor pick up assembly, the pick up sit in side your ignition distributor, replace it and it will start, hope this was very helpful.
May 19, 2010 | 1985 Ford F 250
No start on old gasoline forklift engine.
most likely the ign switch is ok if you are getting spark. so you have a hot spark at coil and weak fire at plugs? if you have a test light check the positive side of coil for power when turning key on and cranking. if it is dropping power on positive side then ign switch could be bad. can "hotwire" coil by jumping a wire to positive side of coil to pos of battery this will eliminate ign switch.
Apr 07, 2010 | 1978 Chevrolet C1500
1986 gas club car weak spark replaced coil still same
How do you know that the spark is weak?
Replace spark plug.
Check spark plug wire for leaks.
Replace fuel.
Clean points and reset.
If there is a battery check that it is at 12.5 during starting.
Sep 09, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Does not have fire on the 2 & 3 cylinders.Plug wires do nnot have fire. How do I check the coil to see if it needs replaced. This is a 1978 KZ 1000 A2.
Cilinders 1 and 4 are on the same coil, so as the 2 and 3 on the other coil.
Remove all spark plugs from engine and plug them in the spark plug leads and against the engine
To check coils easily: switch the low voltage wires from coil 2-3 to coil 1-4.
No spark at 1 and 4 is a sign that the coil is broken.
No sparks at 2-3 is a sign that the ignotion switchbox is broken, or the pick-up coils for 1-4.
Here also, switch the wires of the pick up coils. If allways the same plugs sparks, the switchbox is broken. If the other plugs sparks, then the pick-up coil is broken...
Hope it helps
Aug 22, 2009 | 2003 kawasaki Z 1000
How do i change the spark plugs on a 2003 kia rio
INSPECTION
1. Disconnect high-tension code from spark plug.
2. Remove the spark plug.
3. Connect the spark plug to a high tension code.
4. Hold the spark plug with insulated pliers 5~10mm from a ground.
5. Crank the engine and verify that there is a strong blue spark.
If there is no spark, inspect the following points.
Step Inspection Action
1 Check for good connection of ignition coil Yes Go to next stop.
No Repair or replace
2 Check if resistance of high-tension leads are OK Yes Go to next step.
No Replace
3 Check if the ignition coil is electrically charged
1) Ignition switch "ON"
2) Check if the engine coil (+) is electrically charged
Yes Go to next step
No Check the wire harness between ignition switch ignition coil and ECM
4 Check if resistance of ignition coil is OK
Resistance
Primary : 0.36~0.44Ω (at 68°F (20°C))
Secondary : 10.9~13.3kΩ (at 68°F (20°C)) Yes Go to next step
No Replace
5 Check if ECM is OK Yes
No Replace
REMOVAL
Do not attempt any maintenance on spark plug if engine is hot.
1. Disconnect negative battery terminal.
2. Carefully remove high-tension leads.
3. Use compressed air to blow any dirt or debris from around spark plug hole.
4. Check that spark plug fits squarely in spark plug socket and remove spark plug.
Raise a vehicle and install SST(OK552 131 001) in order to replace cylinder 2, 4, 6 spark plug.
INSTALLATION
1. Install spark plug into cylinder head.
Tightening torque : 18~22lb-ft (25~30N·m, 2.5~3.0kg-m)
2. Reconnect high-tension leads.
3. Reconnect negative battery cable.
Jul 17, 2009 | 2002 Kia Rio
Yamaha big bear no spark
I'm not familiar with all quads and all the kill switch locations. Does it have a tip-over kill switch? Is it working? Is the quad in neutral? Is the neutral light on? Many engines will not spark if the neutral light is not on. Are the headlights off when starting?
How good is your battery? A low battery can kill spark. Test for spark by grounding the threads of the plug against the cylinder. Have a friend kick the bike while you watch for spark. Assuming no spark, then check all the kill switches with an Ohmmeter to be sure each switch is working properly. Sometimes a switch goes bad. Try disconnecting all kill switches then check spark.
Check the wiring harness, even under the gas tank and seat. Are all the connectors clean and with a tight connection? Any abraded wires? Check the ignition switch also. The switch can go bad as well. Are the flywheel coils good > is the battery getting a charge?
Still no spark? If CDI then get it checked.
If points then file or replace them along with a new condensor and reset the gap then time the engine. >> I hope this helps.
Please rate this answer. Thanks trsrhntr!
Apr 02, 2009 | kawasaki KLX 300 Motorcycles
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
