Question about Video Game Consoles & Games
Turske serije sa prevodom - Video Game Consoles & Games
Sir bakit walang kuryenteng lumalabas sa spark plug cable
Hi, Anonymous at ang karaniwang suspects ay ang mga: 1. fouled spark plugs. 2. Malubhang discharged o isang nasira baterya, ay dapat magkaroon 12.5 volts o mas mahusay at maaari able sa pumasa sa isang load test kung kinakailangan. 3. Suriin baterya terminal para sa pinsala o kaagnasan, i-check ang mga cable baterya sa "KAPWA" ay nagtatapos para maluwag, corroded, o nasirang connectors, "SA LOOB" at sa labas ng cable harness, magsagawa connector wiggle test at i-check cables na may isang ohmmeter kung kinakailangan. 4. Loose koneksyon sa pag-aapoy likawin o plug sa pagitan ignition sensor at CDI box. 5. Spark plug cable nasa di magandang kondisyon, shorting / tagas, spark plug cable na koneksyon maluwag, suriin para sa spark tagas sa dilim. 6. Ang maling pag-aapoy likawin, pick up coil, trigger coil o CDI kahon pagsubok pangangailangan upang maging checked sa isang ohmmeter sa 70 degrees Fahrenheit 7. Ang maling kaligtasan switch klats, kickstand, neutral, off / on etc. 8. Ang maling pag-aapoy switch. Good luck at magkaroon ng isang magandang araw.
Sep 29, 2016 | Motorcycles
Tip
When was the last time the SQL Server sa password changed?
With the rights that the sa login has by default in SQL Server, it is imperative to change this password on a regular basis whether it is monthly, quarterly or semi-annually. In addition, as DBAs move on to other opportunities, it is wise to change the sa password as well. Changing sa password should be a relatively easy process requiring little to no impact on the organization. Unfortunately, changing the sa password on a regular basis is not a common practice at most organizations, because the impacts of changing the password are unknown.
Solution
The first step in the process is to find out when the sa password was last changed. If this timeframe is unacceptable to your organization, then steps need to be taken to understand where the sa login is used and how the application can be modified to use another login.
SQL Server 2000 - sa password changes
In SQL Server 2000 a documented process does not exist to determine when the sa password was changed. The best means to determine if the sa password has changed is based on the value from the updatedate column in the master.dbo.syslogins table. This value seems to be the only possible column to determine if any property (default database, default language, etc.) for the sa login has changed. Since the sa properties do not change frequently, the value for this column should be a reasonable, but not an absolute indicator of when the sa password was last changed. Reference the code below to determine the value for the sa login's updatedate column.
USE Master
GO
SELECT sid, [name], createdate, updatedate
FROM master.dbo.syslogins
WHERE [name] = 'sa'
GOSQL Server 2005 - sa password changes
Unfortunately, SQL Server 2005 suffers from the same self documenting issue as SQL Server 2000 as it pertains to the last time the sa password has changed. The modify_date of the sys.sql_logins catalog view can be used as an indicator of when the last property (default database, default language, etc.) for the login has changed. Just as is the case with SQL Server 2000, this value does not guarantee the date ime stamp of the password change, but rather any property change. Since the properties do not change frequently under normal circumstances this value can serve as a reasonable, but not an absolute indicator of when the sa password was last changed. If other properties have changed, the modify_date is not a true indicator and other research/documentation is needed to determine the last sa password change date.
USE Master
GO
SELECT [name], sid, create_date, modify_date
FROM sys.sql_logins
WHERE [name] = 'sa'
GOTo address the risks of changing the sa password, stay tuned for the upcoming tips in the sa series from MSSQLTips.com.
Next Steps
  • If you are scratching your head as to the last time the sa password was changed, then it is worth taking a look at your key SQL Servers
  • If the last time the sa password has changed is unacceptable to you, then begin to work with your team on taking the necessary steps to changing the sa password
    • In addition, stay tuned for the upcoming sa series tips on how to determine who and what applications are using the sa user name and password
  • In order to prevent the sa password from becoming stale in the future, be sure to put processes in place to change the sa password on a regular basis
  • For additional information from MSSQLTips.com check out the following:
    • The first tip in the sa series - When not to use the sa password
    • Stay tuned for the upcoming tips in the sa series:
      • Determine how to find out who and what applications are using the sa user name and password
      • Password management options for the sa login
on Apr 08, 2010 | Computers & Internet
KAILANGAN MAKITA ANG REGULATOR/CHARGER
Hi, Ray para sa sitwasyong ito Gusto kong tumawag sa aking mga lokal na dealer o serbisyo / department bahagi kagalang-galang na tindahan at magtanong tungkol sa anumang mga posibleng mabilis na ayusin o bahagi pagtatanong. Kung kinakailangan transport iyong sasakyan sa dealer o tindahan at magkaroon ng isang propesyonal na tekniko dalhin ito para sa isang test drive, kung ito ay nasa tumatakbo kondisyon, at magbibigay sa iyo ng isang nakasulat na pagtatantya ng pag-aayos at sagutin ang anumang mga tiyak na katanungan na maaaring mayroon ka tungkol sa iyong isyu . Para sa karagdagang impormasyon tungkol sa iyong isyu mangyaring bisitahin ang website sa ibaba. Good luck at magkaroon ng isang magandang araw.
Nov 02, 2015 | Motorcycles
Zeim prevod serije karadayi na srpski jezik
Hier kan ik dus echt niets van maken. Kan het in het Engels of in het Nederlands?
Sep 06, 2014 | Computers & Internet
Anu po ba ang tamang gasolina ng honda tmx 155
Hi, Anonymous na mahusay na tanong, bago ko simulan ipaalam sa akin ang mga motorsiklo na may valves at upuan na dinisenyo upang tumakbo sa leaded fuel isyu, maaari kang magpatakbo ng unleaded fuel na walang isang lead additive na walang problema lamang palitan ang valves at upuan sa mga dinisenyo para sa unleaded fuel ang Susunod na kailangan mo ng isang top end overhaul. Sa sobrang bihirang mga kaso, ang ilang mas mataas na mga engine ng compression ay mag-ping gamit ang pinakamataas na oktano na graded unleaded fuel na magagamit sa mga kasong ito ang paggamit ng isang lead additive o aviation fuel. Ang Octane rating ay isang sukatan ng kakayahan ng gasolina na labanan ang 'magpatumba'. Ang pangangailangan ng oktano ng isang engine ay nag-iiba sa compression ratio, geometrical at mekanikal na pagsasaalang-alang at mga kondisyon ng operating. Ang mas mataas na numero ng oktano ay mas malaki ang paglaban ng gasolina sa katok o pinging sa panahon ng pagkasunog. Ang inirekumendang antas ng oktano para sa karamihan sa mga motorsiklo ay karaniwang oktano 87, ngunit tiyaking suriin ang manwal ng may-ari ng iyong bisikleta. Karaniwan, ang iyong motorsiklo ay hindi makikinabang mula sa paggamit ng isang oktano na mas mataas kaysa sa inirerekomenda sa manwal ng may-ari. Gayunpaman, ang ilang mga modelo ng motorsiklo ay may mga high-compression engine at elektronikong mga kontrol, na idinisenyo upang makinabang mula sa mas mataas na output ng kuryente at pinabuting fuel economy ng mataas na fuel ng oktano. Dahil ang mga pangangailangan ng oktano ay maaaring mag-iba sa mga kondisyon ng operating at kapaligiran, ang iyong bisikleta ay maaaring mangailangan ng mas mataas na fuel o oktano kaysa sa inirerekomenda upang maiwasan ang katok. Sa ilalim ng linya, gamitin ang pinakamababang grado ng oktano na nagbibigay sa iyo ng katanggap-tanggap na pagganap nang walang katok o pinging. Para sa karagdagang impormasyon tungkol sa iyong isyu at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin at pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw.
Honda TMX 155 Review 2014 Review Specs Totally Motorbikes
Fuel consumption of tmx 155 thunder 125 STX 125 CT100
Honda TMX 155 2013 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
May 14, 2014 | Honda Motorcycles
Nedavno sam napunio cetridz 27 color i sada mi ne printa a pokazu je mi da je ketridz pun do vrha izvadim cetridz znaci nije u printeru opet pokazuje da je unutra i da je pun probam isprintati test...
Pokušajte za ?iš?enje mlaznica spremnika s tintom pomo?u ra?unala. U?itaj obi?nom papiru. Otvorite centar Lexmark Solution (idite na Start, Programs, Lexmark XXXX serije, Lexmark Solution Center). Od Odr?avanje karticu, kliknite Clean popraviti horizontalne pruge. Kliknite Ispis. mlaznica stranici ispisuje, prisiljavaju?i tinte kroz o?istiti za?epljene mlaznice. Ispišite dokument opet kako bi provjerili da je kvaliteta tiska je poboljšana. Ako se kvaliteta ispisa nije poboljšalo, pokušajte ?iš?enje mlaznica tintom i do dva puta.
Napomena: Ovo je prera?unavaju translate.google.com.
May 03, 2011 | Lexmark X1150 All-In-One InkJet Printer
Serijal number alkohol120%
If you do not have a lience key for that program you can order it from their website by clicking here
Mar 01, 2011 | Video Game Consoles & Games
Hindi ko na alam kung ano ang password ko sa facebook help naman please !
Nasubukan na niyo gawin ang mga sumusunod:
1) Pumunta sa Website ng facebook o i-type ang www.facebook.com sa internet browser.
2) Sa ilalim ng Password field, may makita ka Forgot your password.
3) Pakipindot ho ito. May lalabas na panibagong web page.
4) Tatlo ang pwedeng pagpipilan para makuha niyo ang password:
A. Email/phone - ilagay yung email or telepono na ginamit niyo sa pag-regiister sa facebook
B. Facebook Username - ilagay yung facebook username ginamit niyo sa pag-register sa facebook.
C. Name and Friend's Name - ilagay yung pangalan mo sa field your name. Sa friends name, ilagay yung pangalan ng kaibigan mo sa Facebook. Pag ito ang napili niyo, ang password mo ay ipapadala sa facebook inbox ng kaibigan mo.
Jan 31, 2011 | Computers & Internet
Walang image na lumalabas kapag nag capture ako sa digital camera ko,ang unit ay canon powershot a470
Ang isang mapagmataas panangga sa bintana ay isa pang karaniwang mode kabiguan para sa mga digital na kamera. Ang mga sintomas ng isang palalo o "malagkit" panangga sa bintana ay halos katulad sa kabiguan CCD imahen sensor. Ang kamera ay maaaring tumagal ng itim na mga larawan (para sa mga panangga sa bintana mapagmataas sarado), o ang mga larawan ay maaaring masyadong maliwanag at overexposed, lalo na kapag kinuha sa labas (para sa mga panangga sa bintana mapagmataas bukas).
Upang kumpirmahin ang isang mapagmataas panangga sa bintana, ilagay ang kamera sa anumang paraan maliban sa "Auto", at patayin ang flash OFF (hindi mo nais na bulag ang iyong sarili para sa susunod na hakbang). Susunod na tumingin pababa ang lens at kumuha ng larawan. Dapat mong makita ang isang maliit na maliit andap sa gitna ng lens bilang panangga sa bintana ang nagbukas at magsasara. Kung kilusan walang nakita, at pagkatapos mong malamang na magkaroon ng isang mapagmataas panangga sa bintana. Kung gayon, maaring tignan ang link na ito para sa karagdagang impormasyon at isang simpleng maayos na maaaring makatulong:
Ngayon A470 ay hindi kaya ng pagkuha ng 15 segundo exposures bilang inirerekomenda para sa ayusin. Sa halip na subukan ang mga setting ng kamera sa manual mode, patayin ang flash, got sa isang darkened room, at kumuha ng larawan. Buksan ang pinto baterya habang ang pula at dilaw na liwanag ay flashing. Kung pagkatapos ng maraming sumusubok na ito ay hindi gumagana, at pagkatapos isaalang-alang ang pagsubok Ayusin # 5a sa site. Subalit gawin ito sa kamera ang pinatay at ang lens retracted upang bawasan ang pagkakataon ng damaging ang lens na mekanismo.
Jan 24, 2010 | Canon PowerShot A470 Digital Camera
A premium problem
Beni maraming salamat saiyo,sa binibigay mo na link medyo,nahuhuli naako meron nang nakakuha ng Best solution.Magtatagalog nalang ako saiyo Ben,nakakahiya saiyo.Hindi kuna aaksayahin itong pagkakataon nato na hihingi ako ng tawad saiyo, "sorry talaga" tungkol doon sa pagkopya ng solution mo,"Cold solder"akala ko noon ok lang,dahil nakita ko sa iba na komopya din,sa solution ko .Dati noong una kung mga solution talagang tinatyp ko mabagal akong magtayp dahil hindi ako sanay sa pagtatatyp at saka sa computer .Kaya lagi akong nahuhuli,hindi ko rin alam ang pagamit ng mga links .Kaya noong nakita ko ang solution mo,akmang-akma sa problema,kalimitan kasi sa electronics epektibo ang cold solder talaga. Maganda ang pagkasulat mo,kaya kina copy paste ko at lagi kung ginagamit ko sa una sa "free solution", hindi ko ginagamit sa "premium solution",iniwasan ko na magkasabay tayo,kaya lagi ako nakakuha ng FIXYA rating free solution. Sa kalaunan akala ko okey lang ginagamit kuna sa "Premium solution" pati,ang iniwasan kung mangyayari na magkakasabay tayo nangyari talaga. Kaya seguro nagagalit ka sa akin,pinopuna muna ang solution ko sa "Misubishi TV tungkol sa sagot ko na "DM" board ,binulgar mo sa lahat saan ko kinokopya yon at tungkul sa kotse din na ginu-googles ko kinuha ang sagot at totoo yon ang lahat nayan,pagtinatamad ako at nagmamadali ako,baka mahuhuli ang sagot ko.
Ang tingin ko seguro nanyayari ito dahil hindi ako nagrespond saiyo sa 'lounge'. Kaya hindi naako pumapasok sa lounge dahil lagi akong pinupuna nila,noon pa. Nagumpisa ito noong nakakuha ako ng FIXYA sa premium solution sa sagot ko sa kotse,tingnan mo ito dito nag-umpisa ang lahat; http://www.fixya.com/cars/t686411-engine_idle
Unang nagalit at nagkomento si ,robotek,tapos nagpa follow up si ekse,sinundan ni abrsvcs,at ibang pang expert na bilib na bilib kay ekse at robotek.Parang nag feel insecure sila pagnakafixya ka o best solution lang.Nakita muna cguro yon ginawa ni robotek sinulat niya ito http://www.fixya.com/ExpertsLoungeThreadView.aspx?thid=718401
Mula nito hindi naako pumassok sa lounge,nakakainis lang minabuting kunalang na huwag pansinin. Lagi ang komento nag googles copy paste,hindi daw ako technician. Maraming top expert nag googles din,si maiksi ,ginko nakasabay ko to sila,tinago ko lang sa premium.Si maiksi lang parang allergic sa akin.Madalas kaming magkasabay,mahilig siya sa maiksi sagot ,parang one liner lang,kaya insecure siya ,baka malaman na siya mahilig mag "place holder",pagwalang makakasabay,saka banatan niya maraming sagot at ang kustomer hindi nag repost kuha na niya. Lagi siyang sumisigaw ng place holder,totoo pala ang kasabihan "kung sinong nagsisili,siya ang hangan". Seguro kung hindi ako technician hindi ako makapasok dito disgrasya lang, ito ang dahilan ;
http://www.fixya.com/support/t668287-burn_resistor Naghahanap ako ng free download schematic diagram.Nagkataon iyon nagpapagaling ako sa operasyon ko sa gall blader.Seaman ako 3RD marine engineer,alam muna pag ang marino nasa lupa ubos talaga lalo na sa kalagayan ko nagkakasakit.May electronics shop ako sa Imus cavite isa at dalawa dito rin sa cebu .Sa pagka ngayon inabalahan ko ay "satellite unlimited" walang load-load,kuha ko diyan sa tondo 5,500 tapos ibinta ko dito sa cebu 25 to 20 thousand,sa bohol ,leyte at saka mindanao.Ang gusto ko sa fixya updated sa repair at makakuha ako ng idea.Sory talaga Ben at saka kay Marked ok lang yong koment mo...
Ikaw Ben tagasaan ka ?Saan ka dati nagtratrabaho..ito number ko 09068050462. Sory pala doon sa lounge bastos kasi yong taong yan si keamo,kabagobago lang niya,kung umasta parang sino.Galit siya sa pinoy tinira din niya si Namizka doon sa car aircon . Hinintay kulang magkamali siya at saka si abrsvs nayan.Etxt muna lang yong number mo...
Oct 01, 2008 | Watches
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
