Question about Cameras
Pico Life D31H - Cameras
Pico life speaker system & alarm clock for ipod
Press the POWER button so it turns on to either AUX, IPOD or FM and then press and hold SET for about 4 seconds. The time should begin to flash and then you can use the + And - buttons to adjust the time. Hope this helps someone.
Jun 22, 2013 | Audio Players & Recorders
What are the specific pico fuses for my RPTV
The amperage is marked on the board right next to them--likely if they go to the convergence circuit they will be marked 5a or 5 amp.
Usually but not always there are more at the convergence chips.
I presume you did not look closely at the board where the two you found are---Sony marks everything.
Jun 15, 2012 | Sony Televison & Video
Where can i get a pico sumo bot kit?
There is currently no pico sumo bot kits. There is actually only one or two pico bots in existence.
Feb 27, 2012 | Televison & Video
I have optoma pk301 pico projector. suddenly few white spots have appeared on screen which do not go away
Hello, I have the same problem with a pico 201, and can not solve it, I can not contact optoma support team
Jul 27, 2011 | Optoma PK201 PICO Pocket Projector...
I have A toshiba 57HX81 tv red ligth blicking.i found (2)5 amp pico fuses at F850 & F851 & (1) pico fuse 2AMP at F852 would replacing these fuses bring the tv back to life.
Too many possibilities to predict if the fuse replacements will make the set function again but I suspect your main power supply has failed so if the fuses blow after replacement, you may have to have the supply repaired or replace it.
You might check, using your model number, at the site below to see if they have a power supply 'pull' available from their stock. They part out retired sets of all kinds.
Jimmy's Parts
Nov 27, 2010 | Toshiba 57HX81 57" Rear Projection...
How do i know which pico fuse is bad on my circut board
This can be tested with multimeter only, set multimeter on continuity and check pico fuse both pins, if meter shows zero ohms resistance that means pico fuse is good.
Sep 05, 2010 | Sony Televison & Video
Pico/ Resistors what are these??
Pico means small and these look like little small resistors, but don't have stripes like resistors, just part numbers. They should measure as a dead short and be in the immediate vicinity of the STK's
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Cameras Logo
19 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
