Question about Keurig B60 Coffee Maker
How do I take apart the top of my keurig vue v500 to unclog it?
I think its clogged
Starts running water when I turn it on, and won't stop
Did you do the unplug, take off reservoir turn upside down and shake a little? It has worked for others.
Here is video of troubleshooting with added upside down theory. Fix Your Broken Keurig Coffee Maker New tips and tricks Water Flow Issues
Nov 28, 2015 | Keurig Vue Brewer V500 Single Cup Home...
I cleaned my keurig and now it doesn't work?
How did you clean your keurig? The way that I do it is fill the tank up with vinegar and run it through. The way that you might have washed it may have clogged it up. Using the vinegar will clean and unclog the machine.
May 04, 2015 | Keurig Elite B40 Coffee Maker
Keurig Elite B40 Won't Close
Pour a 1/2 vinegar 1/2 water solution into keurig and run a few cycles...its clogged
Feb 22, 2015 | Keurig Coffee Makers & Espresso Machines
How do i unclog passenger side sunroof drain on 2002 monte carlo ss?
The way I did it was I used an air hose and blew out the trash
Apr 30, 2014 | 2006 Saturn Vue
I opened my Keurig Vue V700 and found that a tiny gasket had come off. I cannot find the parts schematic and cannot access the area to investigate. Any idea where is goes? I think it is causing a drip...
If it's a small cylinder shaped gasket with a hole through the center, then it goes on the water output post in the head. This gasket has a habit of coming off. Slide it back up the water output shaft. It helps make a pseudo-seal on the top of the k-cup.
Apr 02, 2014 | Keurig Vue V700 Brewing System - 110774
Keurig Vue V700 not filling cup
You are experiencing a clog of the upper tube. Not outside but inside the tube. Use a paperclip, open an end force it up the tube to clear the deposits and your in business. Remember to do a Full cleaning now and again with vinegar solution. Keep Filter changes at least every 4 to 6 weeks.
Jan 18, 2014 | Keurig Vue V700 Brewing System - 110774
Just willl not brew...says it is...I gave it a tap still nothing...I have unplugged and started over....makes noise like it is going to brew then stops
There's a needle that punches a hole on the top of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
Aug 23, 2011 | Keurig Platinum B70 Coffee Maker
Purchased a Keurig B70 in June 2010, I usually have 2 coffees per day or 4 per day on weekends. Water is "softened". After placing K-cup in holder, selecting the brew button, I can only...
Patricia Cross Aug 06, 2017
possibly your keurig is clogged and water can't get pass the grounds...what you have to do is check the area where the water drips out and unclog it...stick a paper clip up it or maybe even a safety pin and move it around to loosen up and unclog ...
Lift up the latch and see where the water comes out,easy fix...
Aug 05, 2017 | Keurig Single Serve Ultra Brewer
Keurig B60 Coffee Maker Logo
141 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
