Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic Projection HDTV PT47WX49E. Can water
Panasonic Projection HDTV PT47WX49E. Can water damage, high humidity and temp, mold and water cause projection problems, ie color off set, poor contrast and color?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 65 Answers
Yes it can any liquid spills or bacteria can rot the system
Posted on Jun 22, 2009
I have a Mitsubishi wd-60735 TV. it is in an unheated garage. Will the cold winter temperatures damage anything? Do I need to bring it inside?
it used to be an issue from when older projection TV's were fluid cooled , but modern lcd projection tv (like this one) don't have any issues in cold weather other than it will take several minutes till picture comes into focus in extreme cold weather , but should not give any long lasting effects once its up at operating temps one thing though don't move it once its hot during cold weather or lamp light source will go out , one thing that will cause long term problems is if its subjected to high humidity (water) this causes all sort of corrosion problems in sets of all types
Oct 15, 2016 | Mitsubishi WD-60735 Projection Television
Temp ligth is on every 5 sec
hi,
there is some thing is over heating inside ur tv. that's why the temp light is lighting. there may be a cooling fan inside the tv . it may be get damaged. find it and replace it.
ok
Dec 16, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Mold and mildew all around the seal.
The only solution here is for you to replace the door seal, and in future, do more high temp washes, as the prob is caused by doing too many low temp washes, ie: 40--50 degree temp washes, this causes build up of bacteria and the like.
Please rate my solution.
Thanks.
Oct 18, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Mold in fire safes is common :(
Most likely, Due to possible dampness in your home collecting in the air tight small container would be the cause of mold. Or it could be humid in the safe that would result to mold because mold would grow in the small dark area. All you really have to do is clean the safe with lysol or some type of antibacteral cleaner..wouldent suggest water alone for obvous reason of it being the possible problem to start with.
Hope this helped.
Aug 16, 2009 | Sentry Fireproof Safe
Whats a panasonic pt47wx49e worth?
In this day and age of low cost LCD and Plasma TVs I would say about $300.00
You can buy a newer better TV (same size for a little more and get a warranty with it!) These are now considered stone age because of the space they take up!
Dec 20, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Pt47wx49e
Check resistor r517 if burnt replace with a carbon resistor 10k at 1/4watt.
Jul 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49E manual
http://service.us.panasonic.com/OPERMANPDF/PT47WX49E.PDF
Jun 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Information
http://www.devicemanuals.com/guide/Television/Panasonic/Panasonic-PT47WX49E-47-PROJECTION-TV-TkRJeU13PT.html
Dec 10, 2007 | Toshiba 55H70 55" Rear Projection...
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
151 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
