Question about RTO Boating
What size socket do i need to change my spakk plugs in my 4 stroke 60 yammie 2006 model
  • 6 Answers
SOURCE: oil change
Hi
see my previous post "oil filters" which basically the same as this
there is a special tool for removing the oil filter "plastic cover " - (a 14 flute 76mm cap type) & this is a "must have " or the cover can be damaged 17mm spanner/socket, 6 mm allen key for the drain in filter housing along with the new filter cartrdge you should also get the 2 "o" rings as well. there is website that Robert Aitchision hs put up which gives a complete description of how to do it with pics & what is needed.
Thanks Robert
http://robert.aitchison.org/tiki-page.php?pageName=Mazda3+DIY+Oil+Change
Can get the filter tool &/or spin-on filter conversion from - see link below
http://www.mazdastuff.com/directory.cfm?CategoryID=242
Posted on Apr 09, 2009
cadman000
  • 607 Answers
SOURCE: changing the oil by myself for the 1st time what size socket
Try a14 mm
Posted on Apr 10, 2009
youredone82
  • 426 Answers
SOURCE: what is the size of the socket i need to change
5/8'' however its a special socket mae to remove an install spark plugs without damagin the porcelin (white part) of the plug, if you crack it the plugs heat rating will be affected.
Posted on Sep 28, 2009
Mike258
  • 1498 Answers
SOURCE: What size socket do I need to change spark plugs
Hi Rmk,
Plugs are one of three sizes;
In order of popularity they are 5/8, 13/16 or 3/4.
Best regards
Mike
Posted on Oct 18, 2009
SOURCE: 2008 dodge avenger spark plug location and socket size.
  • 2008+ Dodge Avenger 2.4L 4cyl.
  • Remove plastic cover on top of engine, just pull on each corner for it is friction fit.
  • Once removed you will see 4 black spark plug covers with one hex type screw holding each.
  • Remove Hex screw and place aside, pull upward to remove plug boot from plug.
  • To remove the plug, use a 5/8 socket with a 6" extension. Once plug has been turned out all the way and you cannot get the plug up and out of the hole, just press the plug boot back on the plug and pull it back up.
  • Gap and replace 4 plugs with the same or equavalent type,. Drop plug down the hole and use socket to align and tighten until just snug, then torque to manufactures specifications.
Posted on Feb 23, 2010
What tools are needed such as socket sizes for front brake and rotor replacement on 2006 saturn vue fwd 4 cylinder
Knowing what socket size to use for your brakes can be tricky, because sometimes it can be changed from how it originally was. I discovered that last month when I was trying to change out my brake pads for my 2005 car and was consulting the manual. If you bought your 2006 Saturn brand new, then you can probably consult the manual and be positive that those sizes are correct. However, if you bought your vehicle old and don't know too much of its work history, then you should consult both the manual and a mechanic before messing with your brake system. http://www.godfreybrake.com/services
Jan 31, 2016 | Saturn Cars & Trucks
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Mar 15, 2014 | 1999 Daewoo Lanos
Replace spark plugs
The OE Autolite plugs installed in the Navigator use a 9/16 inch
socket, which is most exactly the same diameter as the thread area, which makes it look round in the hole. The Champion 7989 uses a 5/8 Spark Plug Socket, which is one of two "standard" plug sizes. The other "standard" plug size is 3/4 inch, which is not used very widely any more.
Nov 09, 2013 | 2006 Lincoln Navigator
Hey i want to service my kx 65 2006 and I want to know the basic to service my bike(what oil and amount)
If this is a 2 stroke engine it does not require an oil change.
If this is a 4 stroke engine most motorcycle manufacturers recommend 10W40 oil and an engine that size should require approximately 3 QTS of oil. However, personally I have always used 20W50 in all of my 4 strke motorcycle engines. You also mentioned a problem what is the problem with the KX 125?
Mar 17, 2011 | 2006 kawasaki KX 125
Can i ask a silly question do i need two stroke oil with this model i think people are winding me up
Engine
Engine type Liquid-cooled, 4-stroke Parallel
Twin
Displacement 649 cm³
Bore x stroke 83 x 60 mm
Compression ratio 11.3:1
Valve/Induction system DOHC, 8 valves
Fuel system Fuel injection: ø 38 mm x 2
(Keihin)
Ignition Digital
Starting Electric
Yes they are!
Mar 11, 2011 | 2006 kawasaki ER-6f
Im having problems tryin to find the right type of spark plug socket for iridium plugs as the socket im using is to chunky for a yzf Thundercat, 96
Hi, measure the thread width,it will be 10, 12, 18mm (depending on typer) and then go to a few auto accessories and bike stores and ask for that particular sized tool that has a thinwall socket. Ask to see all they have! They come in a variety of stytles, (and priced from $5-$75), from simple hex ended tubes with a hole for a bar to slide thru', to swivel headed, flexible stemmed t-bars. I make do with a 12mm tube spanner and ring spanner attached to that to access my Yammy XT600's plug.
Cheers.
Jan 18, 2011 | Yamaha YZF 600 R thunder cat Motorcycles
No spark on all 4 plugs
You will need to remove your ignition coil disconnect battery use proper socket size remove bolts then coil and unplug unit reinstall tighten down bolt and nuts plug coil back in be sure to put ignition wires back in accordance to firing order witch is 1-3-4-2.Now restart engine.
Dec 26, 2010 | 2006 Nissan Altima
2006 3: change spark plugs...
The procedure to replace spark plugs in Mazda -3 2006 model is as follows:--
1)  Start by disconnecting the negative terminal from the battery.
2)  Now remove the black plastic cover from the top of the engine. It snaps into place, so just pull straight up.
3) The four cylindrical gizmo's are the coils which mount directly above the four spark plugs.
4)  Remove the four bolts (studs) that are securing the coils, and pull the connections straight up off the spark-plugs. Remove the plugs with a deep socket, or spark-plug socket.
5)  You may have to grasp the plugs with a needle nose pliers to get them out after loosening them.
6) Install the new spark plugs in reverse method and refit all the wires and bolts which you removed.
Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | 2006 Mazda 3
2006 Chev Cobalt oil filter replacement
i have a 2006 chevy cobalt LT..and i just replaced my oil filter today!!! after several hours of looking i finally looked on the front side of the transmission block.to the left just below the air intake system is a hard heat resistant plastic black bolt topper.it is 1 1/4" in size..i bought a 1 1/2" size and a 36mm size socket torque wrench..both didnt work..1 1/2 was way too big, the 36mm was just slightly too big..took them back, replaced for the 1 1/4" inch socket and voila!!! is was rather difficult..you will need an extender and some good torquing to do to pop it..but once you do it will pop fine..oh, and you will need a 1/2" drive socket wrench.but the 1 1/4"inch socket..pop it onto a 1/2" drive socket wrench with the extender and you are good to go!!
Jun 07, 2008 | 2006 Chevrolet Cobalt
Boating Logo
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
