Question about Brother P-Touch 1850cc Thermal Label Printer
Brother p touch label maker is printing upside down and back to front
  • 5 Answers
SOURCE: brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
Posted on Jul 28, 2008
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Posted on Dec 29, 2008
SOURCE: Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Posted on Apr 30, 2009
paul7of9
  • 1189 Answers
SOURCE: too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Posted on Jan 04, 2010
SOURCE: Brother P touch label maker language settings? how
Tune machine off. Press and hold F and the delete button (2 buttons below the F). Whilst holding these down, turn the unit on by pressing and releasing the power button. Then release the F and delete buttons and the language option will appear.
Posted on Jul 20, 2010
P-touch extra label maker is printing upside down and back to front
You have turned on the "Mirror print" option.
Here is a link to the manual. Go into the print functions and look up the Mirror Print option, that will show you how to turn it off:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
May 08, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
Brother p touch 1100/1800
Often a label printer sticks after a lot of use, especially if you have had a jam. Remove labels and preferably with a vaccum cleaner clean out any dust and bits left in. Turn it upside down and try again.
Then try printing a 'blank label' with no labels in and see if the motor starts. There may be a sensor that prevents this - if so clean sensor
Mar 08, 2014 | Office Equipment & Supplies
Feb 09, 2010 | Brother P-Touch 1000 - Labelmaker -...
Too much tape
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
Need help loading cartridge for brother label maker
when you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Dec 08, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
To reset brother p-touch 1000 e-mail lmtheron@icon.co.za
Hi - You can download the manual by clicking the link underlined in blue below:
PT1000
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Jun 13, 2008 | Brother PT-1000 Thermal Label Printer
Labels are not printing correctly
Brother P-Touch tape label maker doesn't print right.
I believe it's a faulty tape. I put in a new tape, reset the machine and it's now printing fine. It wasn't the reseting - I tried that before.
Mar 11, 2008 | Brother P-Touch 2200 Thermal Printer
Brother P-Touch 1850cc Thermal Label Printer Logo
130 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
