Question about Lands Phones
Change the vm password
I need to change the vm password becasue we do not know what it is. We also do not know which phone is the admin phone. Any suggestions?
Default is 123456789011223344556677889900
Posted on Jun 23, 2009
Why doesn't the message waiting light flash when there is a message?
I assume you have pap2t admin password....
login to admin
click on Line 1 tab.
change "VMWI Serv:" to yes.
save
click on advance view.
click on USER 1 tab
goto bottom.
With vmwi being on, you will get a periodic ring splash to let you know you have VM. You can adjust it here. I have mine set to 0.2 seconds as I like getting a whole house ring to let me know there is new VM, so I don't have to remember to look at the phone/light. Some set this to 0.0 seconds in order to get rid of the ring splash. I also set "Ring On No New VM:" to yes because I have an old caller-id box that needs a ring splash AFTER retrieving VM in order to clear its message waiting light. Newer stuff generally doesn't need this.
save.
You would need to turn off provisioning or your changes will go back to provisioned settings every hour. After you are sure you like the new settings, you can send a ticket to get the settings changed in the provisioned file at VT.
Sep 12, 2014 | Lands Phones
We need help with our Nortel system (T7316E). We don't know the admin password. We have tried Feature 985 and then it says to hit "9" but we can't do that as the display shows VM:363 and we can only hit...
feature 985 shows you your vm extension #.
feature 983 then try 1029999 (if password was changed to 9999 or something else)
or maybe feature 983 then 738662 'ok' then 266344 'ok'. depending on the norstar system you have.
these are some codes to enter the vm management. What are you trying to do, reset a vm password or other system programming?
Apr 17, 2014 | NorStar T7316E Corded Phone
Nortel phone - VM box locked contact admin - tried solutions & no luck
Hi Lyndsay,
Have you tried feature 985, and then press 9, and enter the passed resetsmppwd? That should reset the login on feature 983 to 1020000 for three digit extensions, or 102000 for two digit extensions. Once you get into there, you can reset the mailbox password for the general delivery mailbox. Depending on your system, even though the general delivery mailbox might be on extension 363, the mailbox number is likely to be 100.
Jan 04, 2014 | Nortel T7316E 2-Line Corded Phone
What's the password for meridian general vm box
How do we know? its your system.
Suggest you reset it back to default (0000).
But you need the password for Admin programming (F983).
Once your in do MBOX,CHG, 100 (or 10), RESET
Done
Dec 10, 2012 | NorStar M7310 Corded Phone
An employee just left I I have inherited their phone and extension. How do I access the voicemail system, to set up my voice mail on a partner 18 Avaya? Thanks!
You need the admin password to reset the VM user mailbox. This is the Vm admin pass code, If this has been changed you are out of luck. I can reset the pass code for 25.00 remotely,
Jan 19, 2010 | Avaya Lucent Partner 616 Phone
USED AVAYA ACS V7 PARTNER MAIL vm SYS ANSWERING ALL CALLS, I CAN'T ACCESS VM SYSTEM
Depending on the type of voicemail you have, That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming2.gif.
Oct 06, 2009 | Comdial Avaya Partner ACS Phone
I have a d-link dir-628 I want to change my pass code, what is the easiest way without doing a reinstall
Connect your router to 1 computer withethernet cable.
Then access it with defaults link
http://192.168.1.1
or
http://192.168.0.1
enter user name as "admin" and password as "admin" or blank or "password"
then go to wi fi security then change your WEP key it is your pasword .
You hve to change it becasue it is in * or # format.
If you need more assistanse let me know.
Thanks.
Aug 24, 2009 | Computers & Internet
Need to change main greeting and wipe out an old unknown password
Start here for the Auto Attendant greeting. http://dstech1.com/changing-the-greeting-on-voicemail/
Once you figure out what voicemail this is, you will need to go into Voicemail Admin Programming to re-initialize the password for an extension.
Jul 06, 2009 | Lucent PARTNER18 Corded Phone
Nortel T7316e need to change extention # on phone
You can go to any T7316e phone and do this , press feature 983 when you see log on the screen enter 102 0000 to log on with or 12 0000 this is the default admin password for the voice mail system . it depends if you have a 3digit extension of 2 digit . when you get in you will see three options on the screen above the three buttons , from left to right it will be mbox aa and other press the mbox button then it will give you three more options again from left to right they will be add delete and change press change , it will ask for the extension number , enter the number of your extension . the thing it will ask you is if you want to reset the password , press yes and the press the the red rels button your password is now reset to 0000 . good luck .
Jun 19, 2009 | NorStar T7316E Corded Phone
Locked out of Norstar Voicemail Admin
Sounds like the admin password has been changed. You will have to go thru the vm admin password process to default it.
Dan
Jun 19, 2009 | NorStar M7310 Corded Phone
Lands Phones Logo
44 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
