Question about Electrical Supplies
Our genrator not give output volts - Electrical Supplies
  • 351 Answers
I had a similar problem with a new generator I bought, I removed the cover from the back of the generator and found that one wire had come away from the plastic joiner plug, I removed the part of the plastic connector plug that the wire had to go into and inserted the wire back into it then connected the plug to the other half and started the motor, I connected a drill to the power outlet to see if it worked and it did. You may not have the same problem with yours but it is worth a look.
Posted on May 08, 2014
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
Tip
To play avi video files on s60 3rd genration phones
Many s60 3rd genration phones do not support avi format videos files and in reality the clearity of avi files is more then 3gp so to do this u need to install dvix player on ur phone avilable for sisx,windows phone o.s and then convert ur videos to avi format and enjoy.
on Jun 23, 2010 | Cell Phones
How do I fix my ups back-up with low voltage output, 175 volts only instead of 220 volts?
I would suggest that the battery is exhausted and needed to be replaced.
Jul 16, 2016 | Computers & Internet
No output volt
ceck mosfet on Inverter
Mar 21, 2013 | APC SMX750 UPS System
I want nck code genrator micromax mmx 352g imei to nck code imei no. 911101052026022
i want nck code genrator
micromax mmx 352g
imei to nck code
imei no. 911101052411109
Aug 31, 2011 | Computers & Internet
What is electercity consumption of Minolta 5000 , i want to run it on petrol genrator ..Is 2KV genrator is enoghe
to the best of my knowledge most cameras would work on 110/220 V mains. your 2KV is too much for the camera by far. again if made to work with dc using ac current will ruin the camera.
Jul 04, 2011 | Photography
DEAR When no voltage 235 volts at the entrance to UPS, the UPS output from the device, the voltage is about 165 volts when the device runs on batteries ... At the moment of arrival voltage of 235 volts,...
Hello from America Dragoljub!
I can give you a general answer. I have not worked with this specific Mustek UPS, so the answer will not be specific. However, it should be enough information to help you to fix the problem. I work daily with many UPS and this is a common problem.
I do not believe that you have an equipment problem. It looks to be a configuration problem.
This is very often because of the UPS setup. When the UPS is configured, an output voltage must be selected. It appears that your UPS is configured for USA output voltage (120 volts RMS, about 165 volts peak measurement).
I am sorry that I do not have specifics to tell you how to configure your UPS. This information should be enough to help you solve your problem, though. Consult your UPS manual and find how to re-configure your UPS for 235 volts output and you will be OK.
Good Luck, and Thank You for using FixYa!
Vic
Jun 08, 2011 | Mustek PowerMust 1000 Plus...
Pilot wont stay on
Thermocouple has failed., replace thermocouple or dirty pilot assembly, not enough heat being genrated to produce the 30 mili volts D.C. current to hold the pilot valve open. Clean pilot orfice. Remove assembly and pilot tubing from gas valve. Blow into pilot tubing to remove dirt.. Make sure pilot flame is engulfing the thermocouple.
Jan 25, 2011 | Whirlpool Water Heaters
Register
you can login to www.yahoo.com and there you can register yourself, so click on New here?
Sign Up
and it would give you a form which you need to fill up with your desired user ID and
password and rest of the formalities and then click on creat my account and your account
will be genrated for you.
May 13, 2010 | Yahoo Mail
The telivision would not turn on i unpluged it and it turned on for about ten min and tured back off and has not turned back on since
1. may be problem of power supply [smps] it is genrating more than 110v dc
2.your tv's EHT [ Extra High tention Transformer] or line output trasistor is liqui or over heated contact any qualified service person
Mar 12, 2010 | Televison & Video
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
