Question about eMachines E17T4W 17" Monitor
The monitor on my laptop is pink. I.e., all application backgrouns, start button, desktop icons, scroll bars, etc. etc. It has nothing to do with my "display settings." The pink comes and goes. Can anybody help me?
  • 26 Answers
It has something to do with the connection between your screen and computer.
Try tightening or wiggling the VGA connector between your computer and screen.
Hope this helps!
Posted on Jun 22, 2009
How to reduce ddessktop icon size?
hey wassup
theres two ways you can go at this.
1. right click on an open area on ur desktop and just adjust the icons when u hover over the [view] option
2.make sure ur desktop is the only thing visible and give it one click on an open space just to make sure nothing is selected. then hit ctrl+&
at this point to test if it's working. hold ctrl then start to move your mousewheel on your mouse and the icons will start to all magically increase and decrease in size
now option #1 is a bit more easy and its static
while option#2 is a bit more dynamic and you can really make your icons really big or really small. it's up to you.
Nov 18, 2014 | Computers & Internet
My Hp-620 Laptop is not displaying Wallpaper and no option for it pls help me
Do you mean your laptop shows no start menu, no desktop icons? If its seems like it booted up except nothing is shown on the screen try the steps below.
Click Ctrl+Alt+Del to get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hit the Del key while holding them. Once the task manager opens Clcik the Processes tab then click the Image Name Column heading on the left to get them in alphabetical order. Scroll down and look for explorer.exe. If you see it click it to highlight it then click End Process.
Next, click the FILE tab at the very top left of the window and select New Task (RUN). When the Create New Task window opens type explorer.exe and press ok. Your start menu, task bar and desktop icons will start appearing and populating. if not that means a virus has hidden your files and folders.
If it is not resolved try the steps below:
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 06, 2012 | Computers & Internet
I have the VL193 monitor attached to my laptop via blue cable, have checked all connections and display options, resolution, etc. The desktop background photo appears on the monitor but no Windows icons or...
connect external monitor and look it works properly or not .if problem persists , then format and reinstall the' operating system' . use licenced OS(operating system) to install . before that verify that all drivers are present or not . if not , then take the back up of the drivers .
Apr 19, 2010 | Princeton Digital VL193 19 in. Flat Panel...
Startup fails to complete properly
When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
pls post back and tell me what happens.cheers.
Jan 30, 2010 | Computers & Internet
Moving shadow bars - on applications & windows only
hi, generally it happens when an video card is faulty.. try replacing the video card,, it should work fine..
Sep 27, 2009 | Dell P1130 21" CRT Monitor
Black task bars
I would recommend you to install a application called TuneUp utilities which is a awesome software to restore your taskbars, broken desktops and missing files in windows operating system. Dont worry all your icons would be restored.
Sep 18, 2009 | HP Compaq FS7600 17" CRT Monitor
No short cuts in my screen
are you able to operate your system after it is started. I mean open Windows Explorer ??? Mouse working ?? etc ??
if its only the desktop icons, then try this:
Right Click on Dekstop >> Arrange Icons By >> Show Desktop Icons
Feb 17, 2009 | Dell Computers & Internet
Task-bar & start-menu disappeared
Sounds as if the video card is going down. This is a common problem on these laptops. Have you checked Device Manager to see if the drivers are installed. Hit Win key and pause then select hardware and Device Manager. If nothing seems out of place there then I would most certainly suspect the video card. This is part of the motherboard and not replaceable.
As another check try connecting the laptop to an external monitor via the VGA connector at the back. The resolution problem should be resolved then.
Dec 08, 2008 | HP Pavilion dv6000z Notebook
ACER X193 MONITOR DISPLAY ISSUE
Windows doesn't know your display is broken as it see's your display adapter for the laptop. By adding the monitor windows is adding a second display to the one you don't actually have, your icons and start bar are still on display 1
sorry
Sep 28, 2008 | Computers & Internet
eMachines E17T4W 17" Monitor Logo
115 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
