Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Clear ram on ti84 - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
  • Texas Instru... Master
  • 8,073 Answers
Press [2nd][+] then 7 and choose exactly which reset you want.
clear ram on ti84 - 24363905-q2pwurzke5pnc5434ywey2dm-4-0.jpg24363905-q2pwurzke5pnc5434ywey2dm-4-6.jpg
Posted on Nov 20, 2015
Can I retore a cleared progam on my ti84
If you only cleared RAM, a program that was loaded no longer resides in RAM, but if it was archived, it should still be available.
If you cleared all Including Archives, then it is lost.
Sep 03, 2014 | Texas Instruments TI-84 Plus Calculator
Can't enter numbers
When the RAM is full the cursor changes shape and becomes checkered. If that is the case for your calculator, you should clear the .RAM
Feb 15, 2013 | Texas Instruments Ti84 Plus Graphic...
Ti-nspire with 84 keypad problems
It seems to me that you get the loading bar when you switch keypads. I just switched keypads, and when I reinserted the TI84 Plus keypad back again I found my last TI84 Plus screen contents still displayed.
As to the RAM cleared message, it probably is related to the batteries being depleted.
To verify battery charge level, you may use TI connect.
Mar 31, 2012 | Texas Instruments TI-Nspire Graphic...
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
Everytime I turn on my TI-84 Plus Silver, it stays on for 2 seconds, then shuts off on its own. What can fix this? Other details: When it turns on, sometimes it displays Ans+
Hi mixedgamer12,
The process below should reset your Ti84 plus calculator. If you do this process your RAM memory will be cleared and, you will have to re-install the Ti84 plus calculator's OS.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
    reinsert the AAA battery and then turn the calculator on. The calculator should display the
    message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    "Waiting...Please install calculator software now". Follow the instructions for the
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system in step 3. If the calculator still won't turn on connect the calculator to the computer and, open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? Can you go into Device Explorer?
  3. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator if you haven't already.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  5. If the above process did not work to turn your calculator on, try re-doing the above process. Next time extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Dec 31, 2010 | Texas Instruments TI-84 Plus Silver...
I have 3 unwanted tabs at the bottom of my TI-84 graph screen : Shades, PoI-Trace, ? How can I get rid of these? Thank you!
Natively the OS of the TI84 does not use tabs: It only uses menus and submenus. These tabs come from the game or application you were running before. Terminate the application and clear the RAM because third party applications have a tendency to linger in memory.
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-84 Plus Calculator
Why do some TI83 program work on a TI84 plus and other don't?
Ti 83 and ti84 really have no difference and operate the same. There was something different or you had varibles used by multiple programs that conflicted w/ the ti84 and it would have done the same on the ti83. If you like to rework it and need help email me at raklein62@yahoo.com
Nov 20, 2008 | Texas Instruments TI-84 Plus Silver...
Ti84 "Sin/Cosin/Tan" Problem...
The problem is that you have the mode in radians. You want them in degrees. This is a simple fix. Press mode and then go down to radians and select degrees
Jun 24, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
76 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
