Question about Sensio Bella Sensio 13337 Bella Cucina Triple Buffet Server and Warming Tray
I need a rubber bottom foot for a sensio slow cooker model 1209
I have a Tru double slow cooker and one of the rubber feet has been lost. Is there a replacement I can get?
take the one good foot and replicate it with wood. it's easy.
ask afriendly nieghbor.
Feb 13, 2017 | Crock Pots & Slow Cookers
I need a replacement knob for a Sensio Bella triple slow cooker knob. Part #13490
Fixya does not sell parts. Check with a local appliance parts supplier.
Jun 28, 2016 | Crock Pots & Slow Cookers
Can I replace cracked pot of slow cooker?
I have cracked mine 6 times and always find the replacement for about $6 at Goodwill.
Apr 10, 2014 | Crock Pots & Slow Cookers
Broken lid. Need replacement lid
You might have some luck checking at a "Corning Ware" store for a lid. Write down the dimensions and check there. Best of luck
Sep 26, 2013 | Sensio Bella Sensio 13337 Bella Cucina...
How do you put rubber feet back in to bottom of crock pot? Pound , twist?
I had the same problem, but just found a way to put them back in :
You will need a very small (less than 2mm wide) jewelry-type screwdriver.
Take the bowl out and put the crockpot upside down on a table,
Push the rubber foot back into the base, holding down with your thumb. Then push down on the recessed area of the foot with the screwdriver to get the bottom half of the foot into the base. This will insert one side of the foot. Then push the other side of the foot in, using the same method. During all this, you will apply some pressure with your thumb from the top, but most of the push will be applied with the screwdriver.
This was quick.
I had tried a few other ways, with no success (twist, pound, dip the foot in boiling water to soften it...).
Jun 11, 2013 | Crock Pots & Slow Cookers
I need to buy replacement rubber feet for rival slow cooker. I cannot find a web site that sells them.
I found what appears to be an exact replacement rubber foot for the Rival oval crock pot at ACE Hardware. They're called a "Rubber Bumper" and the part number is #405756. Amusingly this was in the "Automotive" drawer in their small parts area, labeled "General Use: Ford". Ha! Anyway, I had two missing rubber feet and after installation I can't tell these replacements are any different than the originals. Or look here: http://wedo.hillmangroup.com/item/products-19/ts-maintenance-accessories-products-rubber-bumpers/405756-a
Jan 31, 2011 | Rival SCV702 Slow Cooker
Plastic handle on lid broke. Is there a replacement part for this?
Rival cookers are now crock-pot.com. The parts page for your model shows no parts available, but there's a "contact us" link. You can try that and see if they can recommend a replacement handle from another model that might work.
When a friend's cooker needed a new handle, I went to Home Depot and picked up a plain wooden drawer pull and a flat rubber washer (plumbing department). The original handle has a curve to fit the lit, so I used a wood rasp to put a little curve on the bottom of the knob. Then I put the rubber washer under the knob and tightened the screw snugly. That was nearly two years ago and it's still going. So if you can't find the exact knob you can try rolling your own.
Jan 23, 2011 | Rival SCE500 5-Quart Slow Cooker
Lost rubber foot on crock pot
You can find something here that will work. You may have to replace all at the same time so they are a match and it sits level. http://www.levelingmounts.com/bumpers/?gclid=CKXlu_Lrw5wCFcZM5Qod5zN5oA
Eric
Aug 27, 2009 | West Bend 84496 6-Quart Slow Cooker
Missing rubber feet
I called 1-800-5574825 The Rival Company Customer Service Dept. I found my instruction booklet and it had this number. They do not have a replacement part for this item. The customer service person was very polite and said since it was under warranty (under 1 year) she is sending me a brand new slow cooker. Very wasteful since I just need the rubber foot, but at least they are sticking behind their product. I hope this helps someone else.
Jan 24, 2008 | Rival SCV702 Slow Cooker
Sensio Bella Sensio 13337 Bella Cucina Triple Buffet Server and Warming Tray Logo
78 people viewed this question
Top Sensio Bella Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Sensio Bella Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
