Maytage Neptune waher continues filling with water even during the spin cycle
Does it fill when the machine is powered down?
If it does then the fill valve is stuck open and needs replacing
If it does not then you need to check the pressure switch and the air bell on the outer drum which probably has a ball of jellyfied soap in it.
If you take the back off you will see a thin plastic or rubber hose going from the bottom of the drum to a small flying saucer type object.
If you pull the hose off the bottom connection and blow into it you should hear a clicking noise from the pressure switch.
If it clicks then clean out the air bell and refit the hose .
If it does not click then get a new pressure switch
A repairman would test it live but that is not recommended for untrained people
