Question about Canon Selphy CP510 Thermal Photo Printer
Ribbon cartridge stuck - Canon Selphy CP510 Thermal Photo Printer
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
My vintage Royal manual ribbon cartridge does not advance when typing., stuck in same position.
Usually lubriction, there are small pawls or teeth that move gears and pegs that fit into the ribbon. make sure you have the correct ribbon.
Oct 07, 2014 | Royal Office Equipment & Supplies
Disconnected white cable
if it is a flat cable some of them had a little clip that would slide back allowing you to reattach the cable some do not
Jan 29, 2014 | Kodak ESP Office 2150 Wireless All-In-One...
How to install cartridge ribbon on epson printer
Take a ribbon 10-15mrts ,open the cassette with twizer ,take the old one out.
Now ,put new one in such a way (That ribbon is there between the two gears) now rotate the gears & check that ribbon doesn't stuck anywhere.
Feb 16, 2011 | Epson LX-300+II Matrix Printer
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
HP officejet 5610 ink cartridge stuck
Unfortunately nothing else to do but lever them out. Go in from the top and try to hold the carriage at the saem time so you don't bend it - and don't shove anything into the back behind the cartridges or you will damage the ribbon and the cartridge
Jul 23, 2008 | Office Equipment & Supplies
Stuck cartridges
thanks but the ribbon that pulls the cartridges back & forth actually broke,
had to get a new printer
May 28, 2008 | HP DeskJet 932c InkJet Printer
Canon Selphy CP510 Thermal Photo Printer Logo
44 people viewed this question
old marine
old marine
