Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Doc. feeder not feeding at all - HP Officejet Pro L7780 All-In-One InkJet Printer
  • 121 Answers
It sounds like to me that the paper sensor is not working in the adf or the paper may not be in far enough.FOR more free technical support you can visit at---http://tinyurl.com/ng46w9
Posted on Jun 22, 2009
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
Need replacement process for paper feed roller in scanner compartment.
On the doc feeder there are 2 arms that go down into the machine. UNPLUG machine first. You squeeze them carefully and rock the doc feeder backward. It may take some manuevering,
Once you have separated the top half of doc feeder, you will see a wire harness going into the upper half, CAREFULLY unplug it. There are several screws holding down the cover over the bottom half, remove them and again carefully separate this cover from the main body.
Once this is done you should be able to replace the feed roller. One note, while you have it this far apart you ought to change the separaetor pad in the top half.
If this helps you, please log in a vote for me, thanx
Feb 07, 2011 | Brother Fax-1360 Plain Paper Inkjet Fax
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
Getting a dark line on the copy pages. Need a new
Mite be a problem with your doc feeder. Are you using a doc feeder? If so raise up the doc feeder and place an orgnial on the big glass instead of feeding the orginal thur the docfeeder. Does the line disappear? If it does then the **** glass the small glass used by the docfeeder has a mark on it or dirt. Is your machine a printer also? Does the print have the mark/line on them also. Do any of your machine's internal reports have line on them Meter Read print outs etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 25, 2010 | Kyocera Mita Office Equipment & Supplies
Feeds document too far before it starts copying.
The doc feeder is a little finiky, try letting go of the doc as soon as the feeder detects a doc in place and not force it through the feed slot.
Jan 05, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Doc Feed Problem
I would replace the Pick-up roller, Feed Belt, Sepearation roller, and torx Limiter for starters IF you cannot replace them, Clean them with warm water and soap, let them dry, and try the doc feeder, Most Multi feed problems are Torx limiter or clutch problems.
Apr 11, 2009 | Office Equipment & Supplies
The copier keeps saying to put doc. feeder down and i it is. I ha
power supply has the fuse open that feed the voltage for the ardf
Mar 20, 2009 | Toshiba E-STUDIO 450 Copier
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
164 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
