Question about Health & Beauty
Dangers of flaxseied oil - Health & Beauty
How do i know the engine oil is full from the gauge. engine oil light on especially when still warming
When the ngine is cold check your oil level, it should be full according to the dip stick. If the dip stck reads full then you could have a blockage in the system (filter et,,) or the guage is defective. Hopefully you have changed the oil according to the required maintenence schedule, if not that could gum things up.
Jan 04, 2015 | Jeep 2005 Grand Cherokee Laredo
VULCAN oil heater c.1975 UNUSED oil in tank on outside wall. 2 months continuous airflow. Tried turning knob every way, pushing button up/down = ON/OFF (?), unit NEVER USED and will NEVER BE USED.
Not quite sure what is asked, but if you just need to turn off the airflow a breaker or fuse box should be nearby. Flip the breaker and/or remove the fuse. Fuel oil is always dangerous... even a small amount. The lines will still have vapors. Best to remove this unit or flush out the tank and lines and block it off.
Dec 09, 2014 | Heating & Cooling
Fuel oil smell in the house
Fuel oil--- is a #2 oil & sometimes has kerosene in it also & is not like gasoline, that is combustible
Fairly safe,just smells strong
Nov 25, 2012 | Cars & Trucks
Oil press. stop motor is written on the dash. I'm due for a oil change...is it dangerous to drive my car with this notice?
yes, you are in danger of ruining your motor.. check your oil by pulling out the dipstick, wiping the oil of the end of the dipstick and replace it fully down again into the dipstick tube. Pull it out again and check the level of the oil. If it is low, add oil before driving. If it does not show on the dipstick, add 1 quart at time and check the level each time before adding more, until it is to the correct level marked in the dipstick
Mar 25, 2011 | 2004 Volkswagen Passat
My oil dipstick won't go back in. is it dangerous to drive without it?
no it's not dangerous to drive without it, just be sure you know how much oil you have in your motor.The only way to know without having a dipstick in there is to drain all the oil, and fill it up with new oil, unless you are sure that you have no leaks or you know that it doesn't burn any oil.I hope I could help, rate me accordingly, thanks.
Oct 10, 2010 | Volkswagen Jetta Cars & Trucks
I've 1998 Dodge Caravan 3.3L SE. The oil has been slowly leaking since last few years. The cost to replace the gasket is a lot 'cause he needs to remove the engine and so on. Is it worth doing it? I am not...
if the oil is leaking onto the exhuast then yes there is always a fire danger, but the oil lea must be a very big one, more than just a few drops on the ground every nigh.
Sep 08, 2010 | 1998 Dodge Caravan
I have a oil leek arond the oil fliter
thats a bad thing,the oil filter needs to be changed to stop the leak.if not, your motor is in danger!! after changing oil filter if still leaking, it may be oil pan gasket
Aug 12, 2010 | 1983 Oldsmobile Ninety Eight
Stoped running when oil light cam on
oil light coming on usually indicates low oil pressure,your vehicle may have a safety device that shuts the engine down when the oil pressure drops to a dangerous level to protect the engine....hope this helps.....cheers
Jul 09, 2010 | 2003 Lincoln Aviator
Is it dangerous to place oil filled radiator on berber rug.
No, as it doesn't get hot enough to start a fire. The only thing that would be dangerous to your carpet would be if it leaked oil and stained it.
Nov 15, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
I have low oil pressure in my 1994 chevrolet suburban
start by testing your oil pressure sensor, and then if not that drop your oil pan and the screen on your oil pump tube may be restricted. or change the oil pump could be weak
Jan 23, 2009 | 1994 Chevrolet Suburban
Health & Beauty Logo
63 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
