What is a seven sideded polygon called - Computers & Internet
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
Heptagon
Posted on May 08, 2014
SHARP AR-M236 CALL SERVICE CODE L6-10
Hello I found this for your error code.
Code
L6-10
Description
Polygon motor lock trouble
The polygon motor does not rotate. The motor lock signal is detected for 6sec or more after the polygon motor rotates. The motor lock signal is detected for 1sec during rotation of the polygon motor.
Causes
Polygon motor unit failure Polygon motor connection, harness trouble or disconnection MCU PWB failure
I would unplug the unit for a minute and let it cool, then restart it and see if it was a temporary glitch or if the polygon motor has ceased to funtion. You might try to see if the wiring harness has come loose, otherwise you are looking for a new polygon motor.
Here is a copy of the service manual.It also suggests running a SIM 61-1.
https://www.manualslib.com/manual/1065394/Sharp-Ar-M236.html?page=100
I found a replacement motor for the machine, to give you an idea what it will cost to replace, keep in mind if you don't have the ability to replace this yourself you will have to call a repair tech to come in and do it and you may expect the cost for that to be at least the same as the motor.
http://www.precisionroller.com/motors-for-sharp-arm205/products.html
Hopefully it isn't a motor failure. Good luck.
Oct 18, 2017 | Sharp Office Equipment & Supplies
I s a p e n t a g o n a p o l l y g o n ? I w a n t t o k n o w ?
It's my understanding that a polygon is a multisided plain figure ( a two dimensional figure.). This means that a triangle - 3 sides, a square - 4 sides, a pentagon - 5 sides, a hexagon - 6 sides, (I'm not sure but I think a seven sided figure is a heptagon?), an octagon - 8 sides, a nonagon - 9 sides, a decagon - 10 sides, etc. are each examples of polygons.
Mar 20, 2017 | Miscellaneous
Call for service c4000
Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 20 s of the START
signal turning on.
Poor contact in the
connector terminals.
Check the connection of connector YC3 on
the engine PWB and laser scanner unit, and
the continuity across the connector terminals.
Repair or replace if necessary.
Defective polygon
motor.
Replace the laser scanner unit.
Defective engine
PWB.
Replace the engine PWB and check for correct
operation.
Jan 23, 2014 | Kyocera Mita KM-2050 Printer
POLYGONAL ERROR / WHAT DOES THIS MEANS AND HOW I WILL REST IT... THANKS
Polygon error. There is a LASER inside the machine which hits a 5 sided minor spinning at about 35000 rpm. That minor is spun my the polygon motor. More then likely you have a bad print head. That is what the entire assy. LASER/motor/Minor/Sensors are called. Power off/then on if it comes back have a technician looks at it.
Feb 26, 2013 | Minolta MF2800 Plain Paper Laser Fax
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
Lanier 5518 gives a SC320 error code
This SC-320 code error occurs when polygon mirror motor fails or poor connection between BICU & polygon mirror motor please check first the connector of motor if you feel that the connector is good change the polygon mirroe motor it sits inside the LD unit please call the expert to change the part
thanks
Dec 15, 2010 | Lanier Office Equipment & Supplies
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
Error SC320 appear on screen..
Polygonal mirror motor error change...
The polygon mirror motor does not
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Polygon mirror motor defective
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
