Trane XE 1200 ac The outside fan stopped
I have a Trane XE 1200 ac. The outside unit started to to get ''frost on the hose. also the house doe not cool down. Then recently can home to find the outide unit was extremely hot and the fn was not spinning. There is nothing blocking the fn from spinning.
  • 331 Answers
Unless you have a meter youneed to see if the unit is asking the fan to turn on. if so the fan (which i doubt) maybe gone bad or the starting capasitor for the fan... is there anyway of checking the voltage to the fan
Posted on Jun 22, 2009
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
Problem with Air Conditioner
there will be an access panel where the motor is located. 1st thing to check is fuse or circuit breaker feeding the air handler. this is on seperate power from compressor unit outside and usually has a fused or breakered disconnect on the side of the unit. if fuses are good or breaker is not tripped then switch fan mode to on. if blower runs in on but not in auto then it is a thermostat problem. if still no go then turn off power, remove access panel and find the squirrel cage fan blade. make sure it turns freely. it is very common for these motors to go bad. it can usually be removed easily and taken to a motor shop. I use Roy's Electric in Richmond, Va. They can test the motor on the bench and replace it if it is faulty.
Sep 08, 2012 | Heating & Cooling
Trane XE 1100 outside fan works but no cool air in house
Without much to go on, it sounds like you have a leak and lost some charge. It could be many other things but this is a start. I would check to see if the compressor is running, and the indoor fan is running. Is the filter clean? Check these things first, and then call a contractor if they check out ok.
Aug 08, 2012 | Heating & Cooling
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
Trane xe 1000 - 1/4 fan motor went bad - I replaced it with a used 1/3 from another trane unit - it had same wiring harness etc everything starts, runs, cools -cold air - but only for about 5...
Did the 2 fans have the same rpm. If there is not enough airflow through the outside unit the compressor will shutdown on high discharge pressure. Also make sure the fan blades are positioned right if there is a shroud for them. Did the other motor have a capacitor with it or did you use the 1 from the smaller motor. Sometimes the motor data plate will tell you what size capacitor you need. Let me know what you find.
Aug 24, 2010 | Heating & Cooling
Outdoor fan does not come on
most likely it the the cap that is bad. Is this in heating or cooling mode?
Jun 03, 2010 | Heating & Cooling
Heating & Cooling Logo
660 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
